got same problem on my alcatel android phone. it has somethiing to do with heat sensor. I install toogle notification and put battery temperature as notification bar icon. whenever I used the phone for heavy app or charge it with hi-amp charger until it get above 38 degree, it will keep restarting. if it happend, no choice except remove battery until it cool back down.
could be. oNe thing to try is let the battery die completely. Then try an overnight charge. If it still works the same, then the battery has bad cells and will need to be replaced. Good Luck.
1. Battery power / Replace a new battery 2. Other than that you cannot handle the situation, kindly go to the service center and ask him to see there is any virus or software issue in your mobile.
if you turn off the switch for the interior lights,an override,it will prevent the battery from going dead until you can get the door alignment or switch repaired.the interior lights,there is more than 5 will kill the battery for sure.
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
