Question about Leica Digilux 2 Digital Camera
Leica Digilux 2 lens hood and lid - Leica Digilux 2 Digital Camera
When the green light flashes quickly while charging what problem can I consider looking into? Would it be that I need a new battery or a battery charger?
Hi Carmen- I am experiencing the same issue with my 2 DIgilux 1 camera, after a long time of not using them. In fact, One of them had a broken lens motor for the longest time and that seems to have fixed itself. I have 2 new batteries on order to see if thtat resolves.
Dec 23, 2013 | Leica Digilux 1 Digital Camera
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
My digilux2 is completely dead and lost my certificate card. would it be possible to send it to leica? from thailand.
here is the repair website for Leica. They are worldwide and main repair is in Germany.
http://en.leica-camera.com/service/service_and_repair/
Not sure how they will handle warrenty.
May 04, 2011 | Leica Digilux 2 Digital Camera
I received a Leica Digilux 2 from a relative and i cant seem to see anything thru the viewfinder or the lcd screen. Its just black. Is the shutter not open? I can see all the numbers and settings around...
Open the back of the camera. **** the camera as if you were advancing the film. While looking in the back, push the shutter release, like you were taking a photo.
You see the mirror flip up and glimpse a flash of light as the camera cycles.
If you do not see the mirror flip up and return, the camera needs serious repair..
As for the LED Display, put some new batteries in it.
Feb 12, 2011 | Leica Digilux 2 Digital Camera
When I turn on my Leica digilux-2, the monitor shows a photo from the SD card, but does not pick up anything else. The viewfinder is black.
Odd this has been here five months w/o a response. Apparently you describe a "burned out CCD", the famous "sensor problem", which is frequently mentioned whenever the Digilux 2 is being discussed. It's too bad because I think otherwise it is a wonderful camera. Contact Leica in whatever country you live and see what the current policy is re: repair, and whether the company will stand behind their product. There appears to have been positive response. Good luck.
Nov 10, 2010 | Leica Digilux 2 Digital Camera
Best make and largest size of sd card for the leica digilux 2
The Digilux 2 will work with any SD card, but bear in mind that SD cards max out at 2GB. Larger cards are actually SDHC cards and will not work in the Digilux 2.
Apr 18, 2010 | Leica Digilux 2 Digital Camera
New to digital bought a digilux 2 can you suggest a basic camera guide for digilux 2 thanks regards alf
Hello there,
Congratulations for your new Digiluc!
To start , u can get Digiluc 2 Guide here :
http://www.overgaard.dk/pdf/Digilux_Field_Guide.pdf
Install Media picture database software (u can use iPhoto for mac)
or get Microsoft® Expression® for PC (works on mac)
after that, you can set up the camera , for indoor set the lens to f/2 (not automatic).
go shot a lot now :)
hope this help a little :)
Apr 15, 2010 | Leica Digilux 2 Digital Camera
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
Digilux 2 problem
No solution- Humidity and moisture is death to Digital Cameras
Sep 28, 2007 | Leica Digilux 2 Digital Camera
Leica Digilux 2 Digital Camera Logo
240 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
Are you a Leica Camera Expert? Answer questions, earn points and help others
