Question about Brother DCP-330C All-In-One InkJet Printer
Error code 51 brother 330c
I can,t delate this alert. Please help me.
  • 4 Answers
You can disconnect the ink plug
Posted on Oct 02, 2009
I am getting error Unable to Clean 50 My brother printer model is DCP -330C..Anyone got any idea??Plz help
I'm afraid there is no simple solution to this problem.
Error codes 50 and 51 refer to problems with the purging mechanism - some of the whirring and clicking noises you hear when the machine self cleans or starts up are it purging ink from the print head. Through some very clever mechanics, the machine uses the paper feed motor (running in the opposite direction to normal) to perform purging.
Possible causes listed in the Brother Service Manual for this error code range from "simple" things like a misaligned cam, to complex problems with the main control board. However, whatever it is, dismantling these machines isn't staright forward and parts are very diffciult to obtain and very, very expensive, so much so that 99 times out of a 100, it isn't cost effective to repair.
You could approach a Brother service agent, but it's highly probably that they will charge you more than buying an equivalent brand new machine.
Sorry.
Apr 02, 2011 | Brother DCP-330C All-In-One InkJet Printer
Error code 51 how to reset?
the printer does not work due to a paper jam or some sensor problem.
Solution: Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head
Please Visit:
http://pcmediks.blogspot.com
Dec 09, 2010 | Brother DCP-330C All-In-One InkJet Printer
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
Print error 51 .... solution please???
Try disconnecting the machine from the power for about 5 minutes then reconnect to reset, if this persists let me know exactly what the message reads so that I can explain in detail your problem and a solution.
rover620
Sep 16, 2010 | Brother DCP-330C All-In-One InkJet Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean 46 error for a brother DCP-330C printer
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Want the reset info for g46 unable to clean .dcp-330c .and would it be better to clean the waste pad as well?cheers.
Cleaning won't help as it's a counter that sets the error. It's a sealed plastic box that needs to be replaced and then reset thru service mode.Brother only gives the reset codes to authorized service centers.
Nov 27, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-330C All-In-One InkJet Printer Logo
677 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
