Question about Rangemaster 110 (Gas) Kitchen Range
My rangemaster cooker lights on ignition but only stays on low flame is it the thermostat or safety device
    President:
  • 1,653 Answers
It will most likely be the thermostat that is faulty and will neeed replacing. If it wwas the safety device then you would not get any gas at all.
Posted on Oct 02, 2009
  • 13 Answers
Its 99.9% certain it is not the thermostat, it is either the fsd or a blockage on the burner. Contrary to what 57 says, you will get a low rate of gas through to the burner when the safety device has gone.
Posted on Nov 05, 2009
I have a Rangemaster Leisure 110 the left hand oven lights up, but the flame is very low and will not go to maximum.
common problem, there is a device in the oven called a solenoid/ff device these are safety devices and fail after a few years. replacements can be obtained from main stockist Gas On spares on 0121-585-7799
Apr 04, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Oven is igniting but not getting hot
got the same problem on a rangemaster 110 - just had the comet engineer look at it - changed the thermostat and the spark generator - no effect. poss the flame failure device or the timer.
Nov 15, 2009 | Rangemaster 110 (Gas) Kitchen Range
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Gas oven
Its the flame failure device faulty (FFD)
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Dec 18, 2007 | Rangemaster 110 (Gas) Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Left hand oven not getting hot!!
some older ovens did use one side just as a "bread warmer"...only way to tell for sure is to check if there is a burner below the left side
Jun 02, 2007 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Gas) Kitchen Range Logo
609 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
