Question about Acer Aspire™ T180 PC Desktop
Freeze at acer logo screen
When I start up, first I get a blinking cursor at top left. After one minute i finally see the acer logo and the system freezes. I cant go into the bios nor restore the system pressing any of the F buttons. its just dead
    Sergeant:
  • 186 Answers
This is a long shot but it happened to me.One of my usb ports was damaged by forcing the plug in backward which bent the contacts shorting them out.I seperated them with a toothpick which booted the computer.
Posted on Oct 03, 2009
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
Cant get to boot screen to start recovery on e525. I tried every f key! Only get e logo screen which will flash to a black screen with blinking cursor at top left then flashes to all black screen back to...
Some of the emachines coming with Recovery image. You need to press F11 key on starting to check whether the image is available or not. If it is there proceed with restore.
Otherwise you need a recovery CD to do this. If you don't have any CD then you could purchase the recovery disk for your emachines from the link below by entering the serial number on your computer:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Apr 02, 2012 | Acer Computers & Internet
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
My Acer Aspire One shows black screen only.
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Acer Aspire 5100-blinking cursor at top/bottom screen after POST
ok, sounds like its got a few major dramas going on but hopefully we can get things going. if its completely failing to post it can only be a bios, ram or CPU failure. if it is posting but not loading windows there can be a few probles. usually if your switching and installed OS from one to another the HAL (hardware application layer) needs to be re-installed to cope with changes in APTI and single/multicore processors. this can be sorted by using the repair console from the windows installation. the serial number comes up with the registration page automatically put onto the OS when installed from the ACER backup partition. this can be accessed via alt+f10 on posting, as if you were going f8 for safemode.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Acer Aspire™ T180 PC Desktop Logo
303 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
