Question about Ovens
Changing the oven thermostat on a Belling Farmhouse 910 Cooker
The oven thermostat has packed up on my Belling 910 cooker and I have just bought a replacement. They both have the part number 46THC8/J5 but are totally different in appearance.Wiring on the old one appears to be:-Power in to terminals F and 2 (pink wire). Warning (oven on) light is on terminal H (blue wire). Oven light and fan on terminal 6 (white wire) and a red wire which I presume is the live out to control the supply to the oven is on terminal G. The new control has 1 pair of terminals labelled B and another pair labelled C and a single terminal labelled A. I would appreciate information on which wire goes where on the new part. Thanks
Cerfer39
  • 709 Answers
SOURCE: Electrical supply
HI Zuso,
Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
Posted on Nov 23, 2007
noffie
  • 10 Answers
SOURCE: noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Posted on Apr 12, 2008
barkencoa
  • 3463 Answers
SOURCE: cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Posted on Dec 15, 2008
SOURCE: Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Posted on Dec 30, 2009
  • 4 Answers
SOURCE: replacing frigidaire wall oven door light/fan switch
Ask the Frigidaire Agent to go talk to a technician and get the answer to your problem. Technicians are available to the Agents. 1 (800) 374-4432
Posted on Oct 20, 2010
Where is thermostat for oven on belling compact deluxe cooker
which thermostat please try to be more specific
Apr 20, 2015 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
I have a belling farmhouse range cooker but the gas mark numbers have faded so when the oven is switched on we don't know what temp it is on. Is there any way of fixing this?
Set the marker to the level as it is and measure the temperature with a thermometer. Now use a good marker and etch it on the metal body repeat it higher and lower with a gap of say 25 degrees. Have a marking on the knob set in place and now you have made a new calibration to the oven.
Use paint.sticker or anymedium to mark it properly .
Hope my advice helps.
Aug 28, 2010 | Ovens
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Cooker problem
Dec 15, 2008 | Belling Ovens
Cant find the model number on a Belling Format cooker
Hi.
Try looking inside the oven, or at the bottom front
Nov 28, 2008 | Ovens
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
149 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
