Question about Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB Hard Drive
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
As per yesterday, my Toshiba StorE 1 GB stops being detected.
The blue led on HDD is on, but the laptop and PC do not react anymore when the drive is plugged in the USB ports.
Other usb devices are still working fine, so it is not the PC that is in fault.
I assume something is really wrong with the USB part of the electronic device.
It is even possible to unintentionally insert the usb-plug on the drive in reverse, since the dimensions are not very strict.
I hope this is not the cause of an early death of this device.
Is there a simple way to revive the Toshiba 1Tb drive?
(Most probable the eSata harddisk inside is still OK). could reversing the plug have resulted in this failure?
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Posted on Oct 04, 2009
External Hard Drive not recognized
Try another usb cable if that works. But if nothing, make sure if your hard drive can be found in device manager and see if it has a correct capacity. If both doesn't work at all, you have to remove the hard drive to it's case and insert into the pc directly but that might void your warranty. This additional resource link might help you fix your hdd http://adf.ly/dkhUg
Feb 18, 2014 | Toshiba Computers & Internet
Hi Sir My samsung 400 GB external HDD bought from Malaysia is not detecting in My PC. the LED is glowing.. Sathya Bangalore
I am very sorry but malaysian products are not supported with a samsung 400gb hard drive. If you go to a store though they may be able to unlock it like unlocking a iphone
Jun 25, 2011 | Western Digital 320GB MyBook External USB...
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
External hard drive won't connect to computer
first of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
Mar 22, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
My Toshiba external hard drive powers up but my Toshiba laptop doesn't read it. The blue powr light is on and the rive makes a clicking noise. HELP!
Hello there...
Looks like your HDD is having mechanical problem, this could happen due to a shock (dropped or bumped maybe?) which can cause your HDD I/O head loose from its track.
I'm sorry but my advice is prepare a HDD replacement.
hope that helps... :D
Jan 31, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
So i have a Toshiba 1 tb external hdd(px1396e-3t01) for almost 8 months now. It worked perfectly until yesterday evening. I was watching southpark from it and suddenly the led which supposed to light blue...
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 18, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Computers & Internet Logo
1,189 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
