Question about Kenwood KAC-628 Car Audio Amplifier
Power to amp none to sub
Indicator light on amp winks in time to music nothing to sub
  • dion 1666 Dec 21, 2007
    i dont know .but when i turn the volume down it stops flashing .ill try your suggestion
    your rating was a mistake. sorry
  • 631 Answers
If you disconnect the speaker wires from the speaker output terminals of the amp, does the light still blink with the music?
Posted on Dec 20, 2007
Acoustic energy subwoofer makes noise on start-up but then won't play
The light on the rear of the sub indicates it is getting power so it is likely that the internal amp has failed, possibly due to age.
Jan 30, 2014 | Polk Audio Audio Players & Recorders
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I recently change dc jack no power indicator computer lights for a minute then turn off
Remove the main battery and try again, next sub out the ram one at time testing as you go, sub another power supply if possible to be sure it is working correctly. If none of this helps, the motherboard is the next logical suspect.
Apr 02, 2012 | Acer Aspire 5610-2328 Notebook
The main problem I have having is I am getting power to my AMP but no power to the subs. I tested my AMP and subs in another car and everything worked so I know my hardware all works fine. I had someome...
okay , well you need to make sure all your conections are in the right spots, and that your IN LINE FUSE, between your amp and battery, the big glass one is not burnt, just take a look at the metal piece inside , if its a sold metal piece its good, if its burnt in half like a broken bridge it needs to be replaced. the next thing is the fuse on your amp, you need to make sure it is not burnt also. Check your remote that it is hooked up to the right wire. then check that your sub/speaker wires are connected properly and secure. YOUR GROUND WIRE IS HUGE HERE also. MAKE SURE IT IS GROUNDED TO A GOOD SPOT, YOU MAY HAVE TO MOVE IT AROUND A FEW TIMES TO FIND A GOOD GROUND!!!! if you check all of these things, it should work fine.. you can fiddle with your amp and bass settings levels. turn em up so when it works you know it, but not too much you dont wanna blow nothing :)
Mar 12, 2010 | Car Audio & Video
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
No power output from the amplifier...
The EEE and protect leds being on is a clear indication this AMP is toast.
Jun 24, 2007 | Ultimate Sound T3 Series 4600 Car Audio...
Subwoofer seem to be broke
The one sub that you described is gone, there should be no reistance at all when you push on them. It sounds like you got your gains set to high on that amp (maybe the amp is underated for your subs). When you turn up the gain to high your cause your amp to distort and it can get as bad as sending a pure DV current to the sub. That DV current will blow subs because of all the force directed in one direction. If you think about it the amp takes a DC current and turns it into a AC current which creates the frequecy (rate at which it alternates) that alternating current pushes and then pulls on the sub keeping it within its boundries.
Nov 19, 2006 | Eclipse SW9102 Car Subwoofer
Car Audio & Video Logo
97 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
