Question about Ricoh Aficio 1232C Color Copier
Incomplete copying/printing. Full page not copying, just 3/4 of the page, whether b/w or colour. when photocopying or printing only a thrid of the text or image is printed.
  • 48 Answers
This problem could be a couple of things. It sounds as though you may have a bad pcu drive clutch or your drive case assembly belt, gear or tension spring could be broken. I ran across this problem 3 weeks ago and it turned out to be a broken tension spring in the drive case assembly ( this drive case drives the pcu, transfer assembly)
Posted on Oct 20, 2009
    Problem Solver:
  • 10 Answers
Check wether the transfer belt cleaning unit inside the photoconductor unit have wrong cleaning cycle due to the defective cleaning clutch.
Posted on Oct 03, 2009
It is only printing a one colour background,i can not print or photocopy a full coloured document,why.
What is the color that is printing and can you print the machine demo page and or counter sheet?
May 09, 2015 | Konica Minolta Bizhub C452 Copier
What would make a printer only when making a copy or scanning put blue on paper? When printing its not there why?
The Dell 3115 (and Xerox 6180 multifunction, and Lexmark X560) all have a common problem with the INSIDE surface of the scanner platen attracting a deposit. This makes it a little 'cloudy' to look at, and produces a bluish tint to colour photocopies.
Print a test page from the printer that includes colours from all four cartridges. Then make 2 photocopies - one using the document feeder, and one using the flatbed. One may be better than the other - as a work-around.
The REAL solution is to clean the inside of the scanner platen (glass), but you must be very careful, otherwise you'll trash the printer. It is a very complex procedure to remove the scanner platen completely. It can (with great care) be lifted from the front, being very careful not to strain the cables. It can be cleaned successfully.
Apr 30, 2014 | Dell Printers:Dell MFP Color Laser 3115cn
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
I have a lexmark x5630 printer. Since last week whenever i try to photocopy a document, it only copies 1/4 page, not the full page.I have tried to change the "Resize" or "Size" but...
If you're using the Lexmark X3650 printer, try to reset the printer to its Default Factory Settings. Please follow the steps below:
  1. On the printer operator panel, press Setup button.
  2. Select Defaults.
  3. Select Set Defaults.
  4. Select Use Factory.
Then try to make a copy again to verify that the problem is fixed.
Aug 22, 2011 | Lexmark X3650 Printer
Cannot photocopy document
hi...
the colour catridge has nothing to do with the black and white print out if it is a text document. please check you have placed the black catridge propely and in correct positon. and try printing out the pages
Jul 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
Printing and Coping is blank
u have to check the ink catridges(black and colour) in the printer whether the ink is full ,bcos if the ink is low this problem arise check if the printing page is un single colour  if it is then ink is a problem
Oct 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Why is there 2 black ink cartridges in my Canon MP600 printer
On some printers, probably including yours, the black ink will be taken from the reserves in your colour cartridge unless you specifically tell it to do a black and white print on each document, regardless of whether it's printing black exclusively. I wouldn't worry, the black ink in it's own cartridge can also be used for colour photos etc with no detrimental effects.
Mar 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Ricoh Aficio 1232C Color Copier Logo
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
