Question about Epson Stylus C62 InkJet Printer
PRINTER IS TELLING ME IT IS PRINTING BUT NOTHING IS HAPPENING. I HAVE JUST INSTALLED NEW INKS AND THE PRINTER DID A NOZZEL CHECK BUT WON'T PRINT ANYTHING ELSE, NOT EVEN A TEST PAGE. IT WAS WORKING PERFECT BEFORE IT RUN OUT OF INK.
    President:
  • 787 Answers
The nozzle may be clogged. Try with cleaning function on printer.Make sure you remove the tapes from the ink cartridges.
Posted on Oct 02, 2009
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
I have installed a new black and colour ink cartridge but it is only printing in black and blue- why is this?
Your printer head might be blook. For the reason all the colour of ink does not come out through the printer head nozzels. In this condition you should try to come out ink through ink nozzels. procedure
1. print a nozzel cheak. and see what colour does'nt come out.
2. Now open photoshop and take a a4 page and fill it with six colour and print it 5/6 time in a photo paper. If print does not improve call me again. I will give you second tecnique.
Thank you.
Sep 15, 2010 | Epson Stylus C46 InkJet Printer
Ink Problems. is only printing with yellow ink
You may need to replace the Print Head or Purge Unit.
May 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Cant install bought new ink but printer wont work now and it has always worked
Did you remove the tape on the bottom of the ink cartridge? If you did, remove the cartridge a double check under good lighting. It is not uncommon for the tape to tear, leaving a small piece which interferes with the printing. Another thing to consideris how long the printer sat with no ink cartridge. Over time the print head nozzel can become clogged with dried ink. If that happens you can either replace the print head, (which will cost almost as much as a new printer) or buy a print head cleaner and do it yourself. Head cleaning kits are available on the internet for about $10 and usually fix the problem.
Jan 20, 2010 | Office Equipment & Supplies
Printer says out of ink and I put new cartrages in I took off the tape, have put them in and out several times to make sure they are in properly. I have restarted printer and have shut printer off and...
Sometimes when the tape is removed a small piece tears off and remains stuck on the cartridge. Its' happened to me once or twice. remove the cartridge again and check carefully under a bright light. If it is clear of tape there may be dried ink in the nozzel. Use a dampened Q-tip to remove any ink residue.
Worst case would be a clogged print head. After trying everything else and you suspect it may be the print head, you can get a print head cleaning kit online for about $10.
Jan 18, 2010 | Office Equipment & Supplies
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My bjc printer won't print. The paper goes through. The head/cartridge moves like it is printing but nothing. Tried everything in the maintenance manual.
If you have fresh ink cartridges installed and you have run the head cleaning maintenance and still have problems then the problem is most likely the print head ink nozzles are blocked.
This occurs then the printer has not been used for some time. To keep the nozzels from blocking the printer should be used once a week or the clean head maintenance run weekly.
There is no option other than to buy a new print head, they are not cheap.
Sep 08, 2009 | Canon Office Equipment & Supplies
New ink in printer but will not put ink on paper.
It sounds like blocked nozzles to me, providing you're SURE you have good cartridges, properly installed (you did take the yellow plastic tapes off the vents before you installed the cartridges of course).
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results
Mar 07, 2009 | Epson Stylus C84 InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus C62 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
