Question about Refrigerators
FAULT CODE RD COMES UP ON DISPLAY THE FRIDGE FREEZER STARTS UP AND THEN STOPS FLASHING THISA FAULT CODE
    President:
  • 1,462 Answers
The error code "RD" denotes refrigerator defrost error
RD error is usually due to air damper iced up.
The damper in the freezer spins around to close/open the air from the freezer to the fridge.
It ices up from time to time, or the damper motor, or sensor that reads it's position fails.
Very common fault, with samsung refridgerator.
There's a repair kit with a new sensor, damper and bigger heater that's needed to be fitted to nearly every RL33 fridge down here.
If that doesn't work, the damper motor itself is failing.
The dampers used in these fridges aren't an open/close type flap, but a damper that endlessly spins around, hence needing a magnetic position sensor to tell if it's open or closed. The "RD" fault means it's not spun to the position it should be in due to icing up or motor failure, or it can't detect it, due to sensor fault.
Please leave me comments, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 02, 2009
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Hi cant get my Samsung fridge freezer to turn on - just the letters RD appear in the top digital display Any ideas Thx Dave
hi RD stands for refridgerator defrost ...
prob best to switch of for 5 mins and then put back on - has anyone been playing with buttons at front as this can put appliance into service mode where this code can show up ??
samsung fridge freezer diy channel on toutube
hope this helps ">
Feb 07, 2011 | Microwave Ovens
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Fridge beeping
the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Jun 07, 2010 | Fisher and Paykel Active Smart® E522BR...
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Fridge and freezer not cooling down
It seems it's the defrost sensor (freezer side). Waiting for it to come, ordered this morning. It appears to be a defrost fault, having read on the web it seems you can check the defrost sensor with a meter across whilst holding the actual sensor in your hand tightly to see if the resistance changes, anyway it didn't. Will post when the new one comes and I change it.
Sep 12, 2008 | Samsung Refrigerators
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
