Question about 2wire (1000-000057-000) Modem
Power light is red. And now I have no dsl comeing into my computer.
    Scholar:
  • 135 Answers
Modem is bad. Have it replaced. No workarounds unfortunately.
hope this helps
Posted on Oct 02, 2009
  • 603 Answers
Power adapter is bad - check ebay
Posted on Dec 07, 2009
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
Modem d-link dsl 2640U status : connected Power : Red Light LAN (R1) : Green Light DSL : Green Light Internet : Red Light seems that the modem has crash! can't even rest it ! so what should i...
hi
I am techbuddies from fixya .i would like to give a try on your issue.
first of all shut down your modem and your computer then unplugged cables that goes from modem to your computer once it is done then wait for 30-50 sec and then replugge all your calbe and then first turn on your modem and then your computer .This kind of method is called as power cycle of modem.
Once you have done that then check that wether is works or not if not then try to check that is their any kind of red X on your computer on right hand side bottom ,if yes then on run type devmgmt.msc then click OK and the you would be able to log in to device manager .Once the device manager is open look for network adapter click on the plus sign and then under lan right click and click on to enable it .
check wether your internet is working or not .
Also check what is the ip address if comming on your computer .
Inoder to reset your modem .check is their any small hoel in rare-end of the modem if yes please insert a smal pin in to it and press it untill all light flash on and off .
if still the problem comes get back to me on fixya
Sep 09, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Dsl light is red
if the dsl light is red, it means there is no signal coming thru your internet connection. so you need to contact AT&T to check your Dsl line signal
Jun 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Hello
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Jan 12, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
My dsl light is on green but my power light is on red. After a while no lights are on. My router is a 2wire that's about a year old
These 2Wire devices are known to have their wall-wart weaken over time. Although you can measure the proper voltage coming from the wall-wart, when you load it with the DSL modem, the actual voltage drops giving you the red power light. The green DSL light may or may not be accurate while the DSL modem is not getting the power it needs. Look online or go to a store like Radio Shack for a replacement wall wart.
Aug 26, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
2WIRE Single Port DSL Line Filter
i think when you purchased the 2wire modem it usually comes along with 3 sets of single port dsl line filters, try out those other filters see which one works. if the local network light doesn't come on, (are you using 2wire 1000 series?), check the network adapters in your computer, this usually happens when you are using lower versions of OS. try the power outlet in the kitchen / bathroom, if power light doesn't come on, push the reset button for 30 secs. if power light is still off or red, then you may need to replace the modem (check if it's still under warranty, if not you will need to buy a new one.) also you should be using the same power adapter that came with the modem, check the specs. sometimes if the modem is more or less than 3 years old, they could get defective especially if it's often affected by sudden power surges.
Jan 29, 2008 | 2wire Single Port DSL Line Filter (21869)
Blinking light on the DSL modem.
Unfortunately it sounds like the modem may need to be replaced. I had the same issue. Even after doing a complete shutdown, resetting all the cables, restarting the modem and then the computer, it still did not work. After you get the modem replaced, I would suggest you get a spare, possibably from e-bay, so if this happens again, you will not be without DSL Service.
Dec 17, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
2wire (1000-000057-000) Modem Logo
135 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
