I have just got an acer 18 and a half inch moniter and it is tilted forwards and I can see no way of ajusting it
I went to pc world to look at the moniter and checked it was supposed to be ajusted..got home and my son ajusted ours ..just like that!! I still couldn't do it...but it is fine now..
Posted on Oct 03, 2009
    Guru:
  • 355 Answers
Find the user guide...
Posted on Oct 02, 2009
I have a sthil 026pro i know where the screw is for the ajustable oiler but what way should i turn it for more oil
Anti (counter) clocwise increases oil flow (I think - it's been a while).
you won't damage it if you get wrong. Make your ajustment and rev the saw to maximum, pointing the tip of the bar at a reflective surface (about 2 inches away) for about 20 seconds if you see a layer of liquid covering about half an inch wide then the oil is ok.
Jan 07, 2011 | Standard Oregon Chainsaw Chain For Stihl...
Some times wipers would come on with out turning on the wiper switch and now will not turn off at all
Sounds like a bad wiper switch assembly.
Removal & Installataion
  1. Disconnect the negative battery cable. Remove the steering wheel.
  2. On vehicles equipped with tilt wheel, remove the tilt lever.
  3. On vehicles equipped with tilt wheel, remove the steering column collar by pressing on the collar from the top and bottom while removing the collar.
To remove the tilt column control lever, simply rotate it counterclockwise until removed
4ab784d.gif Exploded view of the combination switch mounting and column related wire harness connectors
  1. Remove the instrument panel trim cover retaining screws. Remove the trim cover.
  2. Remove the 2 screws from the bottom of the steering column shroud. Remove the bottom half of the shroud by pulling the shroud down and toward the rear of the vehicle.
  3. If the vehicle is equipped with automatic transmission, move the shift lever as required to aid in removal of the shroud. Lift the top half of the shroud from the column.
  4. On 1991 automatic transmission equipped models, disconnect the selector indicator actuation cable by removing the screw from the column casting and the plastic plug at the end of the cable.
  5. Remove the 2 self tapping screws that retain the combination switch to the steering column casting. Disengage the switch from the casting.
  6. Disconnect the 3 electrical connectors, using caution not to damage the locking tabs. Be sure not to damage the PRNDL cable.
  7. Installation is the reverse of the removal procedure. Torque the combination switch retaining screws to 18-27 inch lbs. (2-3 Nm).
Oct 26, 2009 | 1999 Ford Ranger SuperCab
Cant ajust picture to fill out screen, 3 inches
try this restore to defualt values monitor and cpu
Jul 10, 2009 | Acer Computers & Internet
SCREEN TILT
Is the mounting piece at the bottom of the lcd fixed or not, see if it is placed the right way and inserted the right way, if it is, look on either side where the swivel mounting is, does it move, and if so apply a bit of pressure to move that unit. If not apply 3 in 1 oil to the "hinges" to lubricate it a bit.
May 12, 2009 | Acer P191WBD LCD Monitor
Lap top color disappearing
this is lcd problem , and lcd can not be repaired basically, so u have to replace lcd.
Dec 19, 2008 | Acer Extensa 5620-6119 Notebook
22'' LCD Moniter.
It really depends on your experience you can find many deals. Personally I live view sonic for cost effectiveness and overall performace. I WOULD NOT buy an Acer the last Acer had a static splash screen that burned the dislay wit hte ACER logo on a server in a cabinet. The overall quality was poor on a few others we bought.
I like new egg for my electronics here is a link to a very nice 21.5 inch  view sonic and compared to the Samsung 24 inch (the following link)  http://www.newegg.com/Product/Product.aspx?Item=N82E16824116396&utm_source=http%3A%2F%2Fwww.electroniccarpenter.com&utm_medium=referral&utm_campaign=ec1751pjv The Samsung link is http://www.newegg.com/Product/Product.aspx?Item=N82E16824001309&utm_source=http%3A%2F%2Fwww.electroniccarpenter.com&utm_medium=referral&utm_campaign=ec1751pjv
Personally I am a huge fan of the WUXGA display and is a 3 inch bigger display worth 100.00 to you? If  Ihad 300.00 to spend  I would by the samsung but if cost including shipping is the factor then I would get the ViewSonic.  I would choose one of these two monitors. Based on contrast ratio (great for gamming and video)
Please rate me
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
