Question about ValuSoft McAfee Total Protection 2009 - 3 User - Windows for PC
Since I installed McAfee Totel Protection I have lost my exe. files, so I can not load programs up normally. I have to go to a file and open it up through explorer or my documents. I tried getting help from McAfee but after about five calls they told me that the .exe file was missing! I had worked that out myself.
  • 813 Answers
It seems that your computer was infected by Virus which had affected some exe files. After installing McAfee, it removed those infected exe files due to which you are facing this issue. You may try a system restore to fix this issue, else you need to reinstall the Operating System.
Posted on Oct 02, 2009
0x8ac70013 msn video call are not working
Solution A: If you using McAfee Antivirus, the following steps will configure SiteAdvisor to stop monitoring windows live messenger. Go try solution B if you are NOT using McAfee Antivirus.
1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Solution B: I am using XP with NOD32, using the latest version 2009 (Build 14.0.8117.416) and here is the solution that works for me,
1. Sign off and Exit messenger
2. Go to C:\Program Files\Windows Live\Messenger
3. Right click on file "msnmsgr.exe", select "Properties", a new window of msnmsgr.exe Properties will pop up.
4. Under "Compatibility" tab, look for "Compatibility mode", if the box "Run this program in compatibility mode for" is checked and show window 2000. Go ahead un-check it.
5. Open messenger again and try to test the video call.
Mar 18, 2011 | Home
Tip
Simple ways to Scan with McAfee U3 Stinger
I spend a lot of time with other peoples' laptops with my U3 stick drive if the laptop is on before I try a restart I use this free scanner from McAfee here is the standalone stinger v10.0.1.688 from November 4th 2009 which includes 1370 detections.
http://vil.nai.com/vil/Stinger_10_0_1_624_Threats_List.pdf
http://download.nai.com/products/mcafee-avert/stinger1001688.exe
Here is my U3 version just install it to your stick drive for first line protection and removal
http://depositfiles.com/files/p88wtj4bg
Cheers.
on Jan 13, 2010 | Mcafee Total Protection: Windows
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Can't download mcafee
- the reason why you can't download and install Mcafee is because most likely you have a previous installation of it.
- If that's the case, do this steps:
Step 1 - Uninstall your McAfee consumer products using Add/Remove Programs in the Windows Control Panel Windows 2000/XP
  1. Click Start, Settings, Control Panel.
  2. Double-click Add or Remove Programs.
  3. Select the McAfee SecurityCenter product.
  4. Click Remove and follow the steps provided.
Windows Vista
  1. Click Start, Search, type Programs and Features, and click Go.
  2. Double-click Programs and Features.
  4. Click Uninstall and follow the steps provided.
Step 2 - Download and run MCPR.exe
  1. Download the removal tool from: http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
  2. Click Save and save the file to a folder on your computer.
  3. Navigate to the folder where the file was saved.
  4. Make sure all McAfee windows are closed.
  5. Double-click MCPR.exe to run the removal tool.
    NOTE: Windows Vista users must right-click MCPR.exe and select Run as Administrator.
  6. Restart your computer after receiving the message CleanUp Successful.
    Your McAfee product will not be fully removed until the system is restarted.
Nov 02, 2009 | Microsoft Windows XP Home Edition
I am trying to install new security software having uninstalled Mcafee but am getting a message that Mcafee anti virus file system filter driver is still installed. I dont think that it is but am obvoiusly...
Download the program "Revo Uninstaller" from www.download.com it is a free program that searches out every little nit of a programs existance and snuffs it out. One of the best programs I've seen for uninstalling retail garbage. When you install it and run it. It will give you a listing of all programs currently on the machine, highlight the one you want to get rid of and click on uninstall. Choose option (4), this will search the registry and get rid of everything. The original programs uninstaller will run first, let it do its thing even if it fails, hit ok and Revo will take over from there. Do not let the original program reboot, click no and continue with the Revo program. Click yes to get rid of everything each time you are asked. When it is finished it will tell you.
Sep 15, 2009 | Dell Dimension 2400 PC Desktop
Mcafee anti-virus file sys filter driver removal
try here... this may have what you need. its a removal tool http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
May 27, 2009 | Kaspersky Labs Kaspersky Anti-Virus 2009...
Trojans wont go away. Hijackthis SCAN help
I am of the mind to do a complete reinstall of the operating system including flash the BIOS even if it is the same version. I worked many hours tracking down and thinking you found every part of the problem on to hit an .EXE and it all starts over again....I just clean out everything and start fresh.
If you tell us what make and model of computer along with the operating system it is we can direct you to the drivers for the reinstall. Some off those programs - for example AOL seem to be virus magnets. (if it is a dell it is really simple if you just put in your service code- it give you your particular driver of your computer.)
That is what I would do...Or you can keep hunting.
please leave rating,,,thank you
May 11, 2009 | Microsoft Windows XP Media Center Edition...
Virus (trojan or somthing) Shuts down task manager after a sec.
The only thing I see for now that has been archive by spyware doctor is your braviax.exe. It say it is a rogue malware.
And almost you are running more than 2 antivirus in your system and diagnostic program.
I will post some updates. Try to search for braviax what it is so you can have knowledge first hand.
Can't install Kaspersky. there is mcafee element in system
Follow these directions to download the McAfee Removal Tool and run it to remove the above programs.
  1. Click on the following link to download the MCPR removal tool
  2. Click Save and save the file to your desktop
  3. Close all McAfee Application windows you may have open, and double-click on MCPR.exe to start the removal tool. Windows Vista users will have to right-click on the file and select "Run as Administrator"
  4. After the removal tool finishes, you should be prompted to restart your computer.
  5. Once the computer restarts, your McAfee product should be uninstalled.
  6. If for any reason there appears a red X during the uninstall, go to the following location for more advanced uninstall instructions involving the registry.
    http://tools.mcafeehelp.com/doc.php?siteid=1&docid=419397
Extra Optional Steps
  1. Open My Computer, double-click on Drive C
  2. Double-click on Program Files
  3. Look for any McAfee product folders that remain. Right-click on them and choose Delete
  4. Close My Computer and other folders
PLZ RATE ME BY CLICK YES or NO.
Mar 21, 2009 | Mcafee VirusScan Plus: Windows
ValuSoft McAfee Total Protection 2009 - 3 User - Windows for PC  Logo
Top ValuSoft Computers & Internet Experts
Mike
k24674
Edwin
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
