Tape deck turns on, operation sounds & looks NORMAL- yet won't function
My VERY LOW hrs. tape deck won't play, rewind, FF at any time. It doesn't look broken, or sound like ANYTHING is wrong, when one turns it on.
It worked PERFECTLY when I got it from a family friend for about 2 months. It had been sitting in a closet for over 10 yrs. This unit is VERY showroom condition, It powers ON/OFF just fine..........I'm at a complete loss as to what it could be, besides the 'Bands' that make the little nipple-looking spindles--pull the audio-tape over the surface of the head. But I can't see them, and am not qualified to begin disassembling my Nakamichi in anyway.......
  • Anonymous Aug 10, 2008
    the tape plays sometimes but most often it doesn't .
    will not rewind or fastforward either.
  • flh66 Jan 31, 2009
    Pioneer CT-W404R Double deck . Deck 1 ,play deck works fine . Deck 2 , Play/Record doesnot work at all . Belts are good . Can turn motor with my finger.
  • 79 Answers
Belts are prone to harden over time, like 10 years. The belt probably broke.
If you don't feel comfortable removing the housing yourself, take it to a repair shop.
Posted on Mar 21, 2008
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Teac troubleshooting
Find the phone number for Richer Sounds, they are helpful and deal with Teac.
Jul 22, 2014 | Teac A420 Cassette Deck
Pioneer rt707 ...ff & rewind buttons
I have not seen a RT707 but in the RT909 there are reel settings for the reel motors as far as torque goes. A copy of the service manual will tell you how to set these tensions. I suspect that you have a setting that favors one direction.
Feb 01, 2013 | Audio Players & Recorders
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
FIRST TRY FAST FORWARD AND THEN REWIND. Allow it to ff and rew right to the end of the tape. on the tape. do this a couple of times. this may cure it as it sounds like the tapes are getting an imbalanced tension. If you still haver the problem, dip a cotton bud in alcohol and clean (carefully) the pinch wheel (the rubber bit that drives the tape through) and the capstan (the metal bit the rubber wheel presses against).
Oct 07, 2009 | Technics Audio Players & Recorders
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Feb 04, 2008 | Audio Players & Recorders
307 people viewed this question
