Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
No water comes out when you press the trigger only solution comes out when you turn it on its side
Check the belts. Most models have two belts. The first one from the motor runs both the brushes and the water pump.
Posted on Oct 05, 2009
Water dispenses without pulling trigger. How to stop it?
you should have a lever which controls this spray slid it all to one side then the other sometimes its just trial and error if this doesn't work then see if it has a cut of valve if so it may be broken
Apr 10, 2014 | Hoover F7225-900 SteamVac V2 Upright...
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water/chemical not releasing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
op
Oct 21, 2009 | Bissell 1699 ProHeat Clear View Upright...
Unit is seated properly but water/fluid will not come out when I press the trigger. Suction works fine. Bissell ProHeat 2X used only four times.
You need to check that the motor drive belt is OK and turning freely to drive the water pump - under the flap on the right side at the front as you look at the front of the Bissell. If this is OK have you filled the cleaning bottle with fluid etc? If so you may have an airlock in the pipe from the bottle to the motor. You can also have a blockage from the pump to the dispenser nozzles and can test this by taking off the top cover and taking the plastic tubes off them to see if water comes out of the tube. You can also do the same for the tube from the tank to the pump to see if water is getting to the pump OK. Also make sure that the mix valve setting (on the left side - looking from the front) is not turned to the off position. This could also be blocked and need cleaning or replacing.
Oct 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Water coming out w/out trigger being pressed
You may have a problem with the valve at the bottom of the tank, or a water line has come loose. How old is this, there is a 1 year warranty, so if less then a year, take it in for repair.
Feb 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
268 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
