Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Cannot find where to start on retune, no
Cannot find where to start on retune, no handbook, also not much experience of technical side , need help please
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Posted on Oct 03, 2009
Both ovens and the grill switch themselves off after reaching temperature, once they cool down they start up again, presumably something to do with either the cooling fan or a thermostat? Are either /both...
If you have the handbook, it has sufficient information to enable you to get to the parts that you may need to check. However, working out what has failed is a little more involved and will need someone with electrical experience with a meter etc to work out what has failed.
As an aside, the cut off devices for both ovens are separate. So if both ovens have the same problem, then it could be the cooling fan.
If you need a copy of the handbook supply an email address and you can have a copy via the BT Digital Vault.
Nov 27, 2009 | Stoves 720EF Electric Double Oven
Hi Im looking for jaguar xj6 1996 owners handbook in pdf have not had much luck in searching web for such item
I dont think that there is one, there is one for the technical side of things, just not for the owner/driver.
Oct 24, 2009 | 1995 Jaguar XJ6
No programme info ona Sony TV after the Freeview retune
Unfortunately you haven't said which exact model of Sony tv you have, but there were a lot of their models which didn't behave correctly after the digital retune. In most cases this led to a digital tv freeze.
The official advice is to first try the retune again; from experience I'd add that you need to try it at least twice and to do so at different times of the day in case there is temporary unplanned signal disruption or other environmental factors.
If that does not work then you need to contact Sony directly for advice on 0870 511 1999.
Please cut and paste the following web address into your browser and you'll see a list of Freeview equipment which is known to have incompatibilities with the retune (you need to have Adobe Reader installed). Unfortunately the list has proven to be somewhat less than comprehensive.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my advice to be of assistance and in return ask only that you remember to rate my answer.
Oct 20, 2009 | Televison & Video
Cannot retune channel 5 on my tevion
You need to find a menu which has initial setup, setup channels or scan for channels in it. Without a manual it's difficult for me to guess where it is. Tevion Technical support is on 0161 975 0458
IVE GOT A DTR DIGITAL TERRRSTRAL RECIEVER BUT NOW LOST ALMOST ALL THE CHANNELS I WAS GETTING BEFORE.I HAVE ONLY GOT 5 OF THE NEW CHANNELS INSTALLED
Thanks for the info. You didn't state the manufacturer but I think you must mean the Philips DTR1500/05.
The official advice when a retune has not turned out as expected is to try again at least twice, but from experience I'd add the advice that you should do so at different times of the day.
There are some boxes which are known to have problems with the retune; yours is not on the official list but the channel numbering details which you've given do confirm that it's primarily a problem with your receiver and not with your aerial system or reception quality.
There is no user fix for this. All you can do is to contact Philips directly, but your box is a 2003 model and no longer supported by the manufacturer. OnDigital/ITV Digital/Freeview technical standards have evolved a great deal since then as one operator replaced another and many earlier chipsets have been found to be incompatible.
Contact Philips by all means, but I think that you may be better off investing the £20 or so needed to buy a newer receiver. If it helps, yours uses a lot more power than the newest models so you will make some energy savings and your box was only designed with around a five year maximum expected lifespan anyway.
Sorry I can't give you a more positive or encouraging answer. See the web address below which will show examples of other models with similar or worse issues to your own.
Oct 08, 2009 | Televison & Video
Need to retune my sony digital receiver model vtx d800u cant retune need factory reset pin number
SONY VTX D800(U)
Full Reset (Also clears Pin)
LEFT
RIGHT
YELLOW
BLUE
MENU
Go to Technical Information
Go to Manufacturer Information
Press Red
Oct 01, 2009 | Sony Televison & Video
I have lost the manual for my model SX-K150 Technics organ.
Get the manual there, they will find you every Technics handbook.
Sep 14, 2009 | Music
Retuning a VCR
If you have the original remote, find the menu page that sets up the tuner and either set it manually or use the auto tune feature. If not, get a universal remote with a menu button and do the same.
Finlandia is just a brand name, I'm sure teh VCR is made by one of the usual manufacturers and will work with a universal remote but you have to tediously try all the codes until you find the right one.
Dec 21, 2007 | Televison & Video
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
240 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
