Question about Canon CLC 1140 Copier
Black toner bakgroundi images - Canon CLC 1140 Copier
    Sniper:
  • 118 Answers
Could be the black developer was overtone,needs to change black developer carrier
Posted on Oct 03, 2009
How do i reset the trouble code c 2259
Black image unit motor failure. First open the front door remove the black image unit not the black toner!!!. Take the image unit and shake it so as to spread out all of the developer & toner inside the image unit along the whole length of the unit. The reason for this is as not have all of the developer/toner all at one end and the motor trying to turn with all that at one end or the other. Never store image units or toner vertically!!!!!
Now reinstall the image unit. and close the door. Opening and closing the front door will reset the machine . If it comes back good chance bad image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C451...
We have a c252 and the black toner don't print solid black
how does it print? have you replace the black image unit? NOT TONER THE IMAGE UNIT BELOW THE BLACK TONER CART
Apr 11, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub c451 print out is smudged with black in half page
How do you know the image unit shows toner???? Replace the black image unit
Nov 22, 2013 | Konica Minolta bizhub Office Equipment &...
Xerox Phaser 7750 The printer's black fades print after print and totally vanishes. I tried replacing Imaging Unit, Toner, cleaning by wand, etc.
If it is only happening in black then it has to be something prior to the toner reaching the transfer belt; such as toner, developer, imaging unit, or laser. It sounds like you've already cleaned the laser window, replaced the toner, and image unit, so I would inspect the developer. Remove the black image unit and use a flashlight to inspect how well toner is covering the magnetic roller on the developer. You may want to compare it to a developer of a working color to see if they look similar. Also, make sure there are no foreign objects near where the image units go. If an object came loose in there, the arm will not close correctly which could cause the image unit to not make contact with the developer. Hope this helps, and thanks for using Fixya.
Sep 17, 2011 | Xerox Phaser 7750GX Laser Printer
Printer is saying black toner is out but i just replaced it with a brand new one from Staples
I've been having this problem and it turns out (and here's that bit that makes me look stupid) that I had been supplied with the imaging unit and not the toner cartridge so you may wish to check you've changed what it is you think you've changed. Toner carts are the top row, image units the middle and waste on the bottom.)
Aug 05, 2010 | Konica Minolta magicolor 4650DN Laser...
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
HP 2550n laser - black "toner" on imaging drum.
try replacing your Black toner cartridge first
repost here if it doesn't fix it.
May 05, 2010 | HP Office Equipment & Supplies
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Poor quality black output
There is a defect in the Imaging Unit of these printers....if you replace the imaging unit, the problem of the faded black prints go away. If you have less than 7000 prints, you can call Samsung for a warrantied replacement. The Imaging Unit is supposed to last at least 20,000 prints.
Nov 04, 2008 | Samsung CLP 300 Laser Printer
Canon CLC 1140 Copier Logo
53 people viewed this question
old marine
old marine
