Question about Brother MFC-7820N Printer
Line on printout from scans and copies
When I scan or make a copy the printout always shows a line from top to bottom 7 cm from the left of the page. When I print the problem doesn't exist. Problem exists 4 weeks. I changed the drum and the cartridge, I cleaned the glas surface but problem remains.
Clean the glass AGAIN. I had this issue for weeks. Drove me NUTTTTS! Because I to cleaned the glass. But guess what... not well enough. On your glass there is a tiny .. maybe the tiniest of tiny.....speck somewhere. that causes this line. Trust me I did everything you did and I just knew it was the drum or something. But it wasn't. Sure fire test. Have someone fax you something directly to the machine. (you need something that doesn't pass over the glass) If it prints out fine .. no line... there is a speck on your glass!!! And anything copied, faxed or scanned from your unit will have that line. Ofcourse you have already done half the test yourself if you print something from your computer and dont see the line. Because a print would not pass over the glass either.
Posted on Oct 14, 2009
When using my Samsung M2070F to scan, the scanned copy has a black line from the top to the bottom, just left of the centre of the page.
If you are using the feeder for scan, lift up the feeder and just clean the narrow surface on the left with plastic sheet. DO NOT REMOVE THE PLASTIC SHEET!
Jul 18, 2017 | Samsung Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Copy or Scan problem
Open up the doc feeder and clean the scanner glass
Apr 19, 2010 | HP LaserJet 3050 All-In-One Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Line in the scaned pages
Morgansaki,
You have a dirty scanner lense. when you lift the top cover, as though you were going to do a copy from the platten glass, you will see there is a smaller glass to the left hand side of the scanner. look very hard at this glass and you will see there is a dirty mark on the lense. clean the cglass thoroughly with some quality window cleaner and you will find you line will go away.
Gremlin11
Nov 19, 2008 | Brother MFC-9420CN All-In-One Laser...
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Brother MFC-7820N Printer Logo
151 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
