Pictures
Its very easy.
Step 1:
Go to the picture browser on your cell phone. This can usually be
easily found by pressing the camera button. When the camera loads up at
the bottom of the screen, you should see one of the following options:
"Browse," "Gallery," "Options," or "Tools." Press the button on your
phone that corresponds with one of those (the top-left and top-right
buttons on your phone perform whatever action the text on the
bottom-left and bottom-right of the screen says). If there is only
"Options" or "Tools," then a pop-up menu will open within which you
will be able to select "Browse" or "Gallery."
Step 2:
Select the picture you want to send from your picture gallery. You should now be viewing just that picture.
Step 3:
Find the options for "Send," "Options," or "Tools" at the bottom of the
screen. If there is "Send," push the button the corresponds with it. If
there is only "Options" or "Tools," push the button for that, then
select "Send" from the menu that comes up.
Step 4:
Enter the email address you want to send the picture to in the "To:"
field. Use the numberpad on the phone to enter the letters. Any special
symbols, including @, are most likely under the number 1 - just keep
pressing it in succession until you get the symbol you want. If you
make a mistake, the "Clear" button will backspace.
Step 5:
Press the "Send" button on your phone (the same one you would use to
make a call). Your picture will be sent to the email address you
specified.
Hope it helps.
