Question about Kenmore 62702 Microwave Oven
Kenmore Elite Ultra Heatwave Microwave - Model 665 63799305
Over the oven.
Manufactured date is August 2007. After cooking at 100 power for about 20 minutes, popping sound starts 5 minutes after cooking done and dish is removed. Popping sound lasts for about 10 minutes. If door is opened during the 10 minutes, the sound will stop; however the sound resumes when the door is closed. The exhaust fan comes on automatically.
This oven replaces an old microwave that exhausted to the outside.
  • 9098 Answers
SOURCE: microwave runs constantly
If it's less than a year old, it's under warranty and you should call the nearest Sears store for free repairs. Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your full model number here: (the 3 is correct)
Posted on May 08, 2007
  • 5568 Answers
SOURCE: Kenmore Microwave turned off, not back on
Both of you have suffered at least a failed fuse and these are nearly always inside the housing.
Sometimes the fuse (which are calibrated pieces of special wire) will fail from metal fatigue but it can also mean that either the heavy current, high voltage rectifier that produces the magnetron voltage or the magnetron itself has failed.
Some units have separate fuses for the control and display electronics and another, very high current (~30 Amp)  fuse for the magnetron circuit.
Do not attempt to open the unit unless it is, and has been, unplugged for an hour or more.
Gaining access is generally not difficult and either the back panel or top can be removed with a half-dozen screws. The fuses may not always look the same but the most common is a ceramic case with metal ends and it might be pushed into a simple fixture that snaps over the metal ends.
If you do not own a simple digital multimeter, I recommend buying one. They are available from various sources; electronics and auto parts stores will have them for under $20 US or if in the US, check your local directory for Harbor Freight outlets. I have bought several for $3.00 there and scattered them around vehicles and the normal junk drawer in the kitchen. Even the simplest of these will have several basic ranges and the resistance range is the one used for checking that fuse.       Remove the fuse from its clips and measure it between the metal caps on the low range (often 200 Ohms). If the display does not change, the fuse is blown; if it shows something in tenths or at least below 10 Ohms, it's OK.
If you care to delve further into your microwave at all instead of replacing it (they have gotten almost too cheap to repair), comment back here again and I will try to guide you further.
Posted on Nov 17, 2008
  • 9098 Answers
SOURCE: Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
Posted on May 12, 2009
  • 999 Answers
SOURCE: Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Posted on Sep 15, 2009
  • 1871 Answers
SOURCE: F-9 pops up - microwave stops after 5 seconds.
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
Posted on Apr 04, 2010
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
I have a Kenmore Elite Ultra Heatwave Technology microwave which started smelling "electrical" and it just quit. The lights still work and the panel still works, but it does nothing when you hit...
This almost always means the magnetron tube, which supplies the microwaves, has failed. The smell comes from parts inside the tube that overheat and burn out. Once the tube goes, everything else appears to work but there's no heating without the microwaves.
The tube can be replaced, but the repair should be done by a professional. Microwave ovens are very hazardous to work on, and if the repairs aren't done properly then microwave leakage can be a concern. The tube generally costs around $50 to $75, and I have no clue what labor is going for these days. If you want to keep this oven, let a service technician give you an estimate for the repair. Then you can compare the repair cost against that of a replacement oven. For countertop models, it's usually cheaper to buy a new oven, but for an over-the-range model the repair might be worthwhile. The ovens are more expensive, and yours might be a custom installation.
Apr 20, 2011 | Kenmore 63792 Microwave Oven
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Elite Microwave hood
Please reply back with your brand and full model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 26, 2008 | Kenmore 64683 Microwave Oven
Kenmore 62702 Microwave Oven Logo
358 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
