Question about SuperMicro SUPER X5DAE (MBD-X5DAE-O) Motherboard
Not started server with SuperMicro SUPER X5DAE Motherboard. light 4 red led's, what may i do?
  • tikolomso May 11, 2010
    Here is some great MOTHERBOARD solution by Some FIXYA EXPERT.
    Get any kinds of MOTHERBOARD solution from bellow.
    » Intel Motherboards Solution
    » ASUS Motherboards Solution
    » MSI Motherboards Solution
    » Gigabyte Motherboards Solution
    » EliteGroup Motherboards Solution
    » Compaq Motherboards Solution
    » Foxconn Motherboards Solution
    » Other Motherboards Solution
    50
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
fahima24
Posted on Oct 10, 2009
Date/time
There may be a bad connection in the CMOS battery housing. The battery should make an audible click when it's pressed into the CMOS housing on the motherboard. First, I would make sure that the motherboard BIOS has the latest version R2.1c found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X7DA8
If you can't locate a bad CMOS terminal, you may need to RMA the motherboard. You can check the warranty status here:
http://www.supermicro.com/support/rma/
Apr 18, 2014 | SuperMicro X7DA8 Server Board - X7DA8-B...
I need new driver intel 5000x chipset driver download
Almost all of the drivers are at
http://www.supermicro.com/support/resources/resource_drivers.cfm
Red Hat and SuSe are there as well as Microsoft.
Debian LINUX is on their website.
Jan 26, 2014 | SuperMicro X7DAL-E Server Board...
What do the red diodes D1 - D4 mean?
I do not see anything in the manual about LEDs for D1-D4
Super Micro Computer Inc Products Motherboards Xeon Boards X5DP8 G2 .
However if the motherboard is not posting it could be the RAM. One continuous long beep means that there is no memory detected (D1-D4 may refer to the dimm slots 1-4). You can try booting off of a single stick of RAM, and try different dimm slots to get the motherboard to post.
Jul 15, 2012 | SuperMicro SUPER DP8-G2 (P4DP8-G2)...
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Hi! I get Supermicro U2 server with X5DPA-GG MBO. Cpu and memor modules are ok, but when I turn on server I get long error beep. I took manual and saw that's overheat problem (or should be). But server...
This sounds like a video controller issue. Try booting with a different monitor. Ensure the cables are connected to the motherboard correctly (fans/power/led indicators). Try booting off of a single stick of RAM. Otherwise you may need to check the warranty status and RMA the motherboard to have it repaired/replaced.
1 beep: circuits reset - ready to power up
5 short, 1 long: memory issue
8 beeps: video adapter issue
Feb 21, 2011 | SuperMicro X5DPA-GG Dual Xeon/E7501/FSB...
Hello, I have buy a Supermicro X8DAH+. I have mount 2 x Intel X5670 on the motherboard. When I push the button to start the system, the power is on, the fans run, I ear one beep but the power led...
I dont have specific info on this board, but most of the time you may need to set up a jumper to support 2 cpu's or with the 1 installed go into bios and see if there is a setting there that you can set. Another possibility may be the other chip is bad...swap the 2 out to see if it works...then you can rule that out...go to www.supermicro.com/manuals/motherboard/5500/MNL-1060.pdf...this is the manual for it...
Dec 20, 2010 | SuperMicro X8DAH+ Server Board X8DAH+O...
Unit doesn?t start unless we took all the memory cards (RAM) fro
reset bios setup to factory defaults.
Pull cmos cell for 15 minutesd then check .
Also check RAM frequency is not comflict with each other.
Jun 10, 2009 | SuperMicro X5DAE Motherboard
Supermicro machines
Your server uses a Super P8SCi Motherboard, and according to the manual for your server on page 4-2, you can enter the bios of the computer by rapidly pressing the DELETE key when you first power on the server. This will take youto the bios setup screen. At the top, you'll see an option called boot. Use the arrows keys to navigate over to it, and change your first boot device to the CD-ROM Drive. Then SAVE AND EXIT, and it will now boot from any cd before looking to boot from the hard drive.
Steven
Sep 09, 2008 | SuperMicro (SYS-5014C-T) (SYS5014CT)...
SUPER P4DC6 motherboard.
The P4DC6 supports upto two Intel Xeon processors this link will provide much more detailed information on your board, it also includes all updated software, drivers, bios files and manuals
http://www.supermicro.com/products/motherboard/Xeon/860/P4DC6.cfm
Oct 30, 2007 | SuperMicro Super Micro Desktop Motherb...
SuperMicro SUPER X5DAE (MBD-X5DAE-O) Motherboard Logo
253 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
