Question about Whirlpool Washing Machines
I have a whirpool washing machichine the creaion model. I was wondering if needs a hot water supply or is it ok to use a y shaped hose.
    President:
  • 1,653 Answers
If you have a hot water supply then use it otherwise use a Y hose to connect the cold supply to both hot and cold inlets. Machines are generally made with cold only inlets today as most washing detergents are formulated for cooler washing temperatures and the mfrs say that it is more convenient and cheaper to heat what is required rather than draining your domestic hot water tank. There will not be a problem with using cold fill to both inlets but you can expect some of the hotter was programmes to take longer than expected as the water will have to be heated in the machine to allow the programme to run correctly.
Posted on Oct 02, 2009
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
Model LAT8504AAE Hot water pressure has been reducing over time, little by little. It is now only cold water. All house supply line valves are open.
screen in hot water fill hose is probably stopped up.turn water off unscrew hose at both ends check for a screen,if not in hose check at water inlet on washer pop out screen clean under kitchen spayer and reinstall make sure you put hose washers back in the hose ends that should fix your problem!!!
Jun 12, 2011 | Maytag Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
I am about to buy this model machine but before i do i need to know-does this machine heat up the water itself? or do i have to have a supply of hot water going into the machine in order for it to be hot...
I think you will find that all washers are able to heat water. If they are hot and cold fill, they use the heater if the hot water supplied is not hot enough for the particular wash. If they are cold fill only then they need the heater for all non-cold washes.
If you purchase the washer you are thinking of and it is cold fill only, it will have only one inlet hose, the cold water one and it is a straight forward installation- hose from washer screw into cold supply tap.
If it is hot and cold fill you have a choice- either go to the expense of plumbing hot water to it OR purchase a 'Y' 'tap' adapter. The adapter screws onto the cold supply (by the 'bottom' of the Y) and the hot and cold hoses which go to the washer are screwed into the (top) 2 ends of the 'Y'. The washer opens its hot valve, gets the only water supply which is cold through what it thinks is the hot hose and heats it up accordingly. When it wants cold it opens its cold valve and gets the cold water through what it thinks is its cold hose- which it is!
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 18, 2011 | Washing Machines
HotPoint WF215 Washing Machine I have a Hotpoint WF215 washing machine but it seems as though it is not pulling through the hot water even on the hottest cycle. Ihave checked the hoses to the hot...
Hot and cold water supply is each controlled by an electrically operated solenoid valve which is operated either direct from the programmer on older machines or as more electronics and then computers were increasingly part of washers, by the electronics.
I suggest you visually check the wiring and then check the hot water valve solenoid for continuity. If it is open circuit replace it but if ok check it is receiving mains voltage when the machine should be hot filling - if so the valve could be stuck or blocked and if no voltage it probably needs a new circuit board or programmer.
Nov 10, 2017 | Washing Machines
Whirpool washer reversing hot and cold cycle during rinse
Most likely you will need to insure that you have hooked up the fill hoses to the appropriate input. The inputs on the back off the washer are marked H or C for hot and cold. Double check that the hot water faucet and hose is connected to the input marked H and the cold faucet and hose are connected to the C input. This should repair the problem.
If not..
For further trouble shooting, I will need the model number. It should be found under the lid or on the back of the unit.
I look forward to assisting your further.
Aug 02, 2010 | Washing Machines
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
Whirpool Model# LSR7233BQ2 Top Load Washing Machine. Cold Water not dispensing enough water. Hot water is OK but cold trickles out
This is a typical symptom of a water inlet valve that has either a clog, or a bad solenoid. You can attempt to clean by shutting off the water source and removing the hoses from the back of the washer. Check the sediment screens in the water valve (this is where the hoses connect) and clean as necessary with cotton swabs. If its not a simple clog issue, you will have to replace the valve. The folllowing link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I hope this helps you. If you require additional assistance please let me know.
Aug 11, 2008 | Whirlpool LSR7333 Top Load Washer
Do anyone know what e11 mean on hotpoint wd71 pls
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Mar 27, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
