Question about Mitsubishi TS-5057 50 in. Rear Projection Television
I have a Mitsubishi ts-5057 tv. it's locked. i can't remember the code. i also bought a replacement remote. i have a copy of instructions on turning on tv using Qv button and 9 button at same time, but it doesn't work. any other way to get around lock?
  • boutrous275 Oct 02, 2009
    So i'm looking at the replacement remote now. It isn't a universal remote, but it also dosen't say "Mitsubishi" on in. I guess the brand is "Anderic". I bought it from a website and it said that it was a replacement for the specefic brand and model number of my TV. But it is kinda cheap looking and i know it isn't as heavy as the original one. Do you know where i can get a true "Mitsubishi" brand replacement remote for my tv? The tv is 14 years old and it still works fine expept for it's locked, and i can't get it unlocked. And the store i bought the remote from isn't even in business anymore. Any advice??
    Thanks
    Thank you very much. You've been a big help. I will go ahead and buy another remote from the site you advised. I hope this will fix the problem.
    President:
  • 1,462 Answers
If you forget the code, you can view the locked TV without entering the code.
To do this, simply press the buttons on your remote labeled "QV"
and "9"
at the same time whenever your secret code is requested.
NOTE: These button should be pressed exactly at the same time whenever your secret code is requested.
IMPORTANT:
Unlocking with this procedure is only temporary. To cancel the lock
completely, follow the procedure below
1) Turn on your TV. If the TV requests your secret code, press the "QV" button and the "9" button on the remote control at the same time.
2)Press the MENU button to view the main menu. Use the ADJUST button to select "Advanced" Features". Press ENTER/EXCH.
3) Use the ADJUST button to select "Use Parental Lock". Press
ENTER/EXCH.
4) Press press the "QV" button and the "9" button on the remote control at the same time, instead of entering the code.
5) If you were using "Lock the TV", the lock must be turned off. Using
the ADJUST up/down buttons, select the "Off" setting.
6) If you were using the "Lock the Channel", use the ADJUST up/down buttons to place the cursor next to the channel whose lock you want to turn off. Press ENTER/EXCH.
7) Press the CANCEL button to unlock that channel or use the ADJUST up/down buttons to change the channel to a new one.
8) Press the MENU button to return to the "Advanced Features".
IMPORTANT
YOU MUST USE THE REMOTE CONTROL INCLUDED WITH THIS TV. YOU CANNOT US A REMOTE CONTROL FROM ANOTHER MITSUBISHI COMPONENT AND YOU CANNOT USE "UNIVERSAL" REMOTES FROM OTHER MANUFACTURERS.
IF YOU LOST YOUR REMOTE. PLEASE PURCHASE THE SAME MODEL AND NOT EQUIVALENT MODEL.
please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 02, 2009
MITSUBISHI TS 5057 WONT POWER UP
TS? Sure it is not VS or WS model?
Apr 09, 2012 | Mitsubishi Televison & Video
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I locked my tv because of kids and now i dont remember the passcode
I can only assume that you are not the kids trying to get into the set.
You must have the original Mitsubishi remote control to perform this operation on the set. Look on the remote for a button that is labeled QV (Quick View), if you have this button on the remote then we can press on. Go to the selected channel or input that is asking for the unlock code. When it asks for the code, press the QV button: Holding it down press the number 9 and release. This will unlock the set for this instance. To remove the code I suggest that you go through the setup menu and find the code lock and when it asks for the code use the QV+9 trick again to turn it off from the main menu.
If you do not have the original Mitsubishi remote you will not be able to try this trick. You will have to order a replacement remote from 1-800-REMOTES or www.remotes.com.
Once you have the replacement remote you can unlock the television and be back on your way.
If you have any more quesitons please feel free to reply to this post.
I hope that this helps you with your television lock issues and as always, Thank you for using FixYa.
asnowman
Mar 22, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Apr 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Code to program my tv
normaly press and hold the device you wish to program till the light stays on then enter code if the code is a valid one the light should go off and then you may be able to turn off tv if not repeat steps and use diff code here are the codes i know of for daewoo tv 0130 0004 0009 0100 0005 0138 0043 0140 0039 0252 0279 0444 0080 0042 0058 0017 0010 0126 0018 0127 0019
Feb 18, 2009 | Trisonic TS-1666RFS Remote Control
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
TV Code
you can get the actual remote for that model at www.replacementremotes.com just enter the model number. You may need the service manual to actually erase that code.
Apr 08, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi 3515R , LOST LOCK CODE
Once you get the set to work, go into the menu and turn off the lock. Plain and simple. Good Luck
Nov 20, 2007 | Televison & Video
Trisonic TS-RC488
I HAVE A TRISONIC TS-RC488 AND LOST THE PAPER THAT WAS INSIDE THE REMOTE , THE INSTRUCTIONS CAN ANYONE TELL ME THE CODE FOR A SONY TV AND THE INSTRUCTIONS OF HOW TO SET UP THE UNIVERSAL TRISONIC ,,,, THANKS ,,,,, SINCERELY JOHN
Jan 24, 2007 | Trisonic TS-1666RFS Remote Control
Televison & Video Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
