Question about Black & Decker Drills
When connecting discharged battery to charger Green light comes on straight away but battery doesnt charge .Have confirmed battery is in discharged state.
  • 2,219 Answers
The battery is dead, that is why it does not change from green to red. you need to replace the dead battery.
Posted on Apr 11, 2010
How long will the batters last on kodak m753
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given on a battery.)
Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable.
When the light on the charger comes on, you can assume the charger is working.
If you can charge the battery in the camera everything looks the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours.
I have two Kodak Li/ion batteries and after almost 10 years, they are still on good condition. But I also had to trow away lots of other batteries, before they were about one year of age. (I did charge them wrong, with a high current, more then they could handle)
Aug 25, 2014 | Kodak Easyshare M753 Digital Camera
Lithium ion battery does not last as long
There is no such thing as a memory system in your battery. If you charge the battery until the green light on the charger comes on, that is as much as the battery can/will safely charge to. With Lithium batteries, they will fully charge whether they are at 75%, 50% or 10% capacity when placed on the charger and discharge to 0% if you use them that long. If you need the battery before the green light comes on and you use it, it will still fully charge when replaced on the charger. All batteries do discharge at different rates. Most not noticeably but a few will discharge fast enought to be noticable. If it affects your usage of the tool, you may want to exchange it or get it replaced under warranty because it will only get worse with age.
Mar 03, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
When plugged into the charger the throttle light and charger light are green but when I remove the charger the throttle light immediately changes to yellow and it will not move and i hear a clicking sound
your battery voltage is dropping straight off the charger - batteries are not holding charge & need replacing. You can have your batteries load tested at the battery shop to confirm.
There are guides to battery replacement and trouble shooting here
http://www.razorama.com/razor-installation-guides.html
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
Battery won't charge up
One or more of the cells in the battery may have died while it wasn't being used. LI-Po batteries are memory resistant but they can still develop one if they're left fully discharged too long or at a half charge too long. They require full charge\discharge cycles to keep them from developing a memory.
Feb 13, 2012 | ESKY 001336 20C 11.1V 800mAh Lithium...
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
Non starter ignition lights only come on when battery charger is on. starts when jump leads are connected. as soon as you disconnet leads dies straight away and no ignition lights. battery fully charged.
either the battery is not good or the battery terminals are bad.
the ignition lights should come on , if they do when the charger is connected.
I assume you are connecting the charger or jump cables to the battery terminals
Be careful jumping of a bigger battery it can spike the regulator when the engine starts and tries to produce 50-60 amps
Jun 28, 2010 | 1999 kawasaki ZX-6R Ninja
On the charger it will go red green red green forever and i halve to charge it a week to go ten minuits
hi my son has not used the scooter for a while so i went to charge it and the green light comes on the charger straight away and the scooter is not working can you tell me what the problem is?
Mar 13, 2010 | Razor E100 Electric Scooter
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Drills Logo
157 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
