Question about Canon PowerShot A95 Digital Camera
When camera is switched on I get a clicking sound and an E18 message in bottom left hand corner screen, what is the cause of this?
  • Canon Master
  • 4,738 Answers
Test
Posted on Oct 02, 2009
  • CameraR
    CameraR Oct 02, 2009
    Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
    Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
E18 screen msg
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Whirring sound after start then black screen with E18 in bottom corner
this is very easy to fix- switch your camera on, grab then lens around the edges, and carefully give it a firm twist. It should click and turn on.
Dec 18, 2007 | Canon PowerShot A400 Digital Camera
Trouble with lens and blank screen
http://www.e18error.com/repair.htmls shows pictures of how to take apart a similar camera.
need an online translator from Bulgarian.
Canon Repair is out of the question.
Dec 09, 2007 | Canon PowerShot S30 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Mar 29, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
