KOSS CD player will not read CD says '' no disc
When I put CD in the player tries to spin, but stops and says no disc?
  • Anonymous Apr 06, 2009
    Ok, my koss CD+Tape+and raido player wont work!
    So what should i do the tape and raido work but it wont play the CD
You need to Clean the laser lines inside the cd player I can do that for you if you want me to
Posted on Apr 02, 2009
    Sniper:
  • 108 Answers
1.Your Disc might be damaged
2.Your cd player laser beam reader lens might be weak or dead
3. Check whether it happens to all Disks
4. if it does not play all the disks then you have to change the laser diode lens assemble.
5. contact service centre to fix news lens
Posted on Dec 22, 2007
  • shanth shanth
    shanth shanth Dec 22, 2007
    1.then the problem with the cd player laser beam reading assembly and its associating blocks
    2. i guess your cd player laser beam lens is too weak or dead.
    3. There is possible to change the lens system with a new one
    4.Contact service centre for further rectification
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Koss cdp4045 cd player won't regonize new cd
it might be to old if not make a copy of the disk try again if not get a new cd player for £3.50
Dec 31, 2008 | Koss CDP4045 Personal CD Player
Cd player does not work
unplug it, unscrew the screws holding the cover on, you should be able to see the lazer lens where the disks go, now take a q-tip with rubbing alcohol on it and gently rub the lens in one direction to remove any dust. cd players are very picky about dust and even just a little can give you a no disc error. ive had to do it to many cd players, so this should work for you! good luck
bryan
Apr 01, 2008 | Audio Players & Recorders
Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
Player reads no disc
try to clean the lens use coton and water. do not use cleaning disc.
Sep 17, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
DVD Player turns on spins says reading but there is no picture or sound.
I had same problem and once left the player on for 3 weeks (left for vacation) and it still never worked. Finally had to dissassemble body of player to get dvd out. There appears to be no solution to this problem. I have called it quits and this cheap piece of junk is now in the trash. Koss will never be on my list of best buys.
Feb 27, 2007 | Koss KS2503 System
496 people viewed this question
 Grubhead
Grubhead
