Question about Epson Stylus Color 1160 InkJet Printer
Printer states there is no ink. Cartridges are changed but a red light stays on
    Scholar:
  • 115 Answers
Are these refilled cartridges or new ones? New ones will always work but sometimes refilled ones get overfilled or the sponge is dry and the printer cannot read it properly. Check to make sure the copper links that connect the cartridge with the printer are clean. This also helps. You may also have to re-align it before you can use it. Cheers.
Posted on Oct 02, 2009
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
EPSON C60 RED LIGHT FLASHING ON CENTRE BUTTON CANT STOP IT
shellnbarry, As I stated in a previous post the red light flashing means an ink cartrdge is low but not empty. When the red light stays on it means an ink cartridge is empty. You can continue to use the printer until the red light stays on.
Nov 12, 2009 | Epson Stylus C60 InkJet Printer
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Red light stays on after i changed ink? will not print
the red light shows an error/alert
make sure when you installed the cartridges
they are properly snapped inside
also check if the printer printed a test page
as it is must once you put the new cartridges
youmay also try uninstalling the cartridgesand turn of the printer,perform a power flee
turn it back on and install it one by one .
Jul 09, 2009 | Epson Stylus cx7450 All-In-One InkJet...
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
I am trying to refill my ink cartridge and i dont know how. HELP!!!
When your ink starts getting low, you will see a red light flashing on the printer. There is a tear drop shape next to the indicator light on the top of the printer. You can keep printing until the light stays red. Once the light stays red, they will need to be changed. When you need more ink, Epson will have a window pop up on your computer wanting you to purchase ink from them. You do not need to do this. We bought our ink cartridges at Best Buy. This printer uses DuraBrite Ultra Ink. There are 2 types; 69 or 88. They recommend 69 for heavy use and 88 for moderate use. The 88 has about half the ink the 69 does. We buy the 69 because it lasts much longer. We use this printer about 3 times a week on average and we haven’t had to change the ink for about 6 months. The 69 black ink at Best Buy is less than $20.00 and the color ink is about $14 for each of the 3 colors. The color 88 comes with all 3 in a pack and it’s about $30.00.
You should not remove any old cartridges until you are ready to replace them because if there isn’t any in there it can dry out the nozzles. You open the scanner and press the stop button and the printer head moves to the correct position. Open the cover and squeeze the tabs that are there and remove the old ones. Then as mentioned in the set up, insert each one in the correct color and press until they click. This printer was actually the easiest that I have ever had when it came to changing the ink. Another thing that you should know is that you cannot refill the cartridges. They have to be new.
Dec 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
