Question about Motorola Mobility MOTOROKR EM30 Cell Phone
It not work properly.no music play.not click on option multimedia
Default player
With this option selected when you click a music or video file to play it will play back only via VLC player. You can still play back a file with another media player, but you will have to right click on it and select the option to play back via an alternative player. Even after playing back the same file using an alternative player, the file if clicked normally will still play back via VLC player.
Jan 04, 2014 | VideoLAN VLC
How to add files to Multimedia plyaer
To add file to your multimedia player,:
1. Open your multimedia player,
2. At the top-left of the multimedia player, you will see 'FILE'.
3. Click on FILE, and you will see different options. Choose 'add media file' or 'import' as the case may be.
4. Choose the specific file/files you want to add then click ok. Your media files will be added as soon as this is done.
You could also go to your files normally, when the multimedia player is closed.
1. Click the windows 'start' button, then go to your documents, or music or which ever folder your media folders are. Hold the control (Ctrl) key, and begin to highlight these file on e afrter the other.
2. After you must have highlighted everything, remove your hand from the 'Ctrl', and right click. You should see different options, like, "open", "play", "add files to media library", "play with media player", "add files to VLC media player", as the case may be. Click on the option one of the options that carry add, e.g "add files to media library". Once this is done the earlier-highlighted media file will be added to your media library or media player. Hope this helped.
Apr 22, 2011 | Cell Phones
I am having Samsung s5620 monte mobile handset. The mp3 player in this mobile is not working properly. It is not playing entire album. only one song is repeatedly playing. usually it should play one song...
DEAR FRND, OPEN YOUR MUSIC PLAYER -YOU WILL SEE OPTION ON MUSIC PLAYER AS(ROCK,[1][S],) CLICK ON MIDDLE ONE TO MAKE IT A WITH ARROW FACING STRAIGHT...HOPE THIS WILL HELP
NJOY N CHEERS
Dec 26, 2010 | Samsung Cell Phones
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Windows media player 11 not playing music properly
Yes click on START-PROGRAMS-ACESSORIES-SYSTEM TOOLS-SYSTEM RESTORE, here restore your system back to a date that it worked perfectly, don't worry you won't loose any files. good luck
Jun 08, 2009 | Microsoft Windows Media Player
I closed itunes and the music is still playing and it wont open back up
if your on a mac, and you clicked the red close window circle (top left of itunes window), you haven't quit itunes yet, to quit properly and stop it playing music use command + tab to go back to itunes, then press command + q to quit
Apr 23, 2009 | Apple iTunes
Itunes not playing files at all.
There could be one of two probelms. Either the files aren't coppied into the itunes music folder when you import them, and they have been deleted from their original location. This means that the link itunes uses to points to the files obviously wont find them since they're gone.
To change this go to preferences, then advanced, then tick the check box next to import music into itunes folder.
Or, when you upgraded, the itunes files were somehow moved and itunes can't find them any more. You can correct this by clicking on the file to play music, and when it asks you if you want to locate the file, select yes, and search through your computer to your itunes folder (or wherever the files are kept), and select those as your music files. It should now build a new link to that file, and play your music.
Hope this helps,
Nathan.
Mar 17, 2009 | Apple iTunes
Wont auto play any disc
First off thanks for choosing fixya.com
It could be that "autoplay" has been disabled. Here are some steps to enable autoplay.
  1. Double click on the My Computer icon on your Desktop until it opens.
  2. Then gently click on your CD / DVD Rom Drive just until it becomes highlighted.
  3. Then click on the word File, which is contained in your top tool bar area.
  4. This will pull down a menu for you to now click on Properties.
  5. Then click on the Auto Play tab at the top of the screen.
  6. You can adjust settings for Music CDs, Music Files, Pictures, Video Files and Mixed Content.
  7. Now select a multimedia types by using the pull down arrow to the right with your mouse.
  8. Then for each multimedia type, use your mouse to encircle the Select an action to perform: option.
  9. To disable that multimedia type, click on the Take no action icon at the bottom of the screen.
  10. Now click on the Apply button at the bottom of the screen to save your changes.
  11. Continue in the above fashion for each multimedia type, choosing the Take no action option.
  12. And ensure that you click on the Apply button at the bottom of the screen to save your changes.
  13. Once all options have been set, then click on OK button to exit the CD Drive Properties window.
  14. Repeat the above procedure on any additional CD Rom Drives you have in your system.
  15. Note: If you feel you have made a mistake, you can click on the Restore Defaults icon at any time.
You can also double click "My Computer" then click the drive letter the cd/dvd is in. If nothing still happens it may be a failing or broken cd/dvd drive. Ensure that the cd's are clean and free of any major scratches.
Hope this helps you out
Jei.
Dec 15, 2008 | IBM ThinkPad T40 2373 Notebook
Music
make sure the files are in the Music Folder. After you open the audio player in Multimedia, press the button with the the three white dots on the left of the phone (options button). Select "Options" and then "Add". Open "My Music" folder and click on "select". It will copy the mp3 files in the folder to the audio player playlist.
Nov 24, 2008 | Dual Electronics N99i Cellular Phone
Cd rom does not working
the auto-notification could not be enabled, do the following:
# Double click on the My Computer icon on your Desktop until it opens.
# Then gently click on your CD / DVD Rom Drive just until it becomes highlighted.
# Then click on the word File, which is contained in your top tool bar area.
# This will pull down a menu for you to now click on Properties.
# Then click on the Auto Play tab at the top of the screen.
# You can adjust settings for Music CDs, Music Files, Pictures, Video Files and Mixed Content.
# Now select a multimedia types by using the pull down arrow to the right with your mouse.
# Then for each multimedia type, use your mouse to encircle the Select an action to perform: option.
# To disable that multimedia type, click on the Take no action icon at the bottom of the screen.
# Now click on the Apply button at the bottom of the screen to save your changes.
# Continue in the above fashion for each multimedia type, choosing the Take no action option.
# And ensure that you click on the Apply button at the bottom of the screen to save your changes.
# Once all options have been set, then click on OK button to exit the CD Drive Properties window.
# Repeat the above procedure on any additional CD Rom Drives you have in your system.
# Note: If you feel you have made a mistake, you can click on the Restore Defaults icon at any time.
Jan 10, 2008 | Compaq Laptop / Notebook Video-336970-001...
Motorola Mobility MOTOROKR EM30 Cell Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
