Question about Cell Phones
Have v9x Motorola music goes of anytime I have music for when my husband rings me, it plays the same music of a night time when hubby is asleep next to me front screen still has main picture on it no number, when it goes of at night same song, and locks up different times in photos I take out battery and start again thanks carol
Unlock at&t motorola razr v9x
Hi, You can unlock a Motorola Razr V9X safer and easier using unlock code. You can get the unlock code for a Motorola Razr V9X from www.wickedunlock.com/motorola-razr2-v9x/rs11wp9/ at affordable cost.
Sep 28, 2012 | Motorola Mobility RAZR2 v9 Cell Phone
Calendar alert does not ring when event is planned
Good morning to you
Ijust know onething about setting alarms and that is. To do it in the right order. When I set mine (nokia)firstly I find software in software there is a clock. New alert- alerts- world clock
I click on new alert then on the screen fill in what is asked.
I can also do this trough the calender- check if this works for you..
also check if alarm sound is on if not put it on.
all the best
Kolbrun
Feb 24, 2012 | Motorola Mobility Motorazr2 V9x Cell Phone
Change ring tone
How to Change the Ring on a Motorola V360
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
Instructions
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
Thank you for choosing fixya
Roger
Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
V9x soaked in the rain - hoow expensive to fix?
remove all covers and battery, take out the sim card and then wrap it all in tissue paper and place in an airing copboard or very warm, dry room. Leave it for 24 hours, re-assemble and should be good to go, if not it is probably not woth fixing.
Feb 07, 2010 | Motorola Mobility Motorazr2 V9x Cell Phone
Sending music
usually, you have to go to the actual music file and select the send option, this will then give you sending options such as send via bluetooth or mms.
Jun 27, 2009 | Motorola Mobility Motorazr2 V9x Cell Phone
What does "Refreshing Database" mean
try holding the power button and the play button for 20 secs at the same time
Oct 12, 2008 | SanDisk Sansa e260 MP3 Player
What does "Refreshing Database" mean?
You will need to upgrade or reinstall the firmware on your MP3 player. You may download the firmware on http://www.sandisk.com/Retail/Default.aspx?CatID=1376. For the manual installation of the firmware upgrade, you may go to this site: http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Not getting constant play back
This is an excellent system for a bedroom or small office area. The random color changing light feature is very soothing to fall asleep to as well as the random/all disc playback so you don't fall asleep to the same thing every night! The 90 minute max sleep timer is just perfect to give me time to read a little and still be able to fall asleep to music. I also use the random playback feature during the day to play my parrot's training CDs so he doesn't get bored either! This is a great system and I highly recommend it.
Aug 01, 2008 | Emerson MS3105 CD Shelf System
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
