Question about Cisco Computers & Internet
How can I obtain the password recovery files for Cisco LD-417
How can I obtain the password recovery files (unlock3002.bin) for this device?I recently purchased the LD-417 on ebay for my home lab and the device was password protected.
2 Suggested Answers
Grumman_1
  • 12 Answers
SOURCE: have cisco load director 417. need unlock3001.bin
As long as you are registered on Cisco's site you can download it from there... You have to be logged in prior to launching this URL...
http://www.cisco.com/pcgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/web/localdirector/unlock3001.bin&swtype=FCS&software_products_url=%2Fcgi-bin%2Ftablebuild.pl%2Flocaldir&isChild=&appName=&tbtype=localdir
Posted on Jan 18, 2010
How to recover files accidentally wiped out
Hetman Uneraser quickly recovers deleted files and folders from just about any kind of storage media. Hard drives, memory cards, external storage, USB drives - you name it! The tool will reliably recover accidentally deleted files even if you used the "permanent delete" function with Shift + Delete, and restore data cleared from the Recycle Bin.
https://hetmanrecovery.com/file_uneraser/hetman_uneraser.htm
Dec 03, 2017 | Computers & Internet
Tip
877 router factory reset woes
Question:<br> We've recently changed <a href="http://www.3anetwork.com/cisco-c2951-vsec-sre/k9-price_p267.html"><b>C2951-VSEC </b></a>data line providers and now have some Cisco 877 routers we'd like to reconfigure and use at other sites. Although we own these, they were configured by our old data line providers, I'm having a hard time of resetting them to factory defaults and am after some advice.<br> The simple, hold down the reset button until it restarts does not work.<br> If I press the reset button within 5 seconds of power up to load the default rom image, I get the below:<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:c870-advipservicesk9-mz.124-24.T.bin<br> Error opening: flash:c870-advipservicesk9-mz.124-24.T.bin<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:/c870-advsecurityk9-mz.124-24.T6.bin<br> Self decompressing the image : ############################################################################## [OK]<br> I assume from this the required bin has either been removed, renamed or overwritten.<br> As soon as the router boots it requires a password and I dont have the password to be able ftp files in and out of it.<br> Hope you guys can help.<br> Answer: <br> this should work indeed.<br> take a look here:http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml <a href="http://www.3anetwork.com/cisco-cisco3925/k9-price_p284.html"><b>Cisco 3925</b></a>
on Aug 28, 2013 | Computers & Internet
Cisco password recovery
Depends on the device. Have to go to a Cisco forum for the quickest help or directly to Cisco. Just call them. Act like it is urgent! :)
Feb 23, 2015 | Cisco Computers & Internet
What do I do if I forgot my password?
Well, if you forgot your password, you will need to completely reset the device to factory settings. There should be a recessed button on the back that is only accessible with a pin or paperclip. Press that and it will reset all of the settings to default.
Sep 02, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
I need to reset my AS5300 series Router that came with a username and a password
If you need to reset the enable password for your device, here is the page from cisco that links to the password recovery methods of all of their gear:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 08, 2011 | Cisco AS5300 SERIES IOS ENT PLUS IPSEC...
Have cisco load director 417. need unlock3001.bin file to reset password
Jan 10, 2010 | Computers & Internet
How to reset password of pix 506e
You only need a PC and a serial terminal. First of all you need to know the PIX software version you run. After that you must go to Cisco web page and get from there the utility for the password recovery corresponding to your version of software.
After that you must connect to the PIX console port. Press ESC key after the PIX is booting and a special prompt it will appear (monitor>). Issue the "interface" command to specify which interface to be active. Inside interface it will be the default one. Then use the command "address" to go with the IP address of the above interface. After that, you will need also an TFTP server where you must upload the software utility specified in the beginning of the solution (the one downloaded fron Cisco). After the "address" command, issue an "server" command to put the IP address of the TFTP server. Than, use the command "file example.bin", where the example.bin is the file downloaded from Cisco. Maybe you will need also to specify the gateway of your network. This you can accomplish by using the "gateway" command. Finally, use the "tftp" command to start the download.
The default Telnet password after this process is "cisco."Go into configuration mode and issue the passwd your_password command to change your Telnet password.
Best regards,
T
Apr 24, 2009 | Cisco Computers & Internet
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Cisco Router Boot Loop
you need to follow the steps to perform a password recovery on the router.
don'y actually perform the password recovery step, but you need to get a uncorrupted copy of the isos installed.
then try again.
I have assumed that when you power on the device you are able to see the boot process in hyperterminal, then just befor you get to type anything the unit reboots.
Oct 28, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Computers & Internet Logo
103 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
