Question about Canon imageRUNNER 5570 Copier
000025-00001 i replace moter sensor check wiring conector
  • 1 more comment
  • yadav_vijay3 Oct 02, 2009
    Vijay Yadav
    please solve my problem
    canon photo copier ir 5570
    problem error code e000025-00001
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
Its the toner bottle motor that is giving this error code, common problemn is dirty sensor or the bottle motor is not working.
Posted on Oct 02, 2009
How do you replace the wiring pigtail for the thermal transmitter on a 98 nissan altima?
You need a soldering gun and electrical shrink tubing to repair this.
Dec 19, 2016 | 1998 Nissan Altima
Need wiring diagram for 2002 honda accord MAP sensor
google this for a diagaram or check you Tube
Feb 16, 2013 | 2002 Honda Accord
I have a 00 reg toyota camery 2.2ltr. My car just cuts out when im driving. I have replaced the coil leads, plugs, fuel filter and the fuel pump.
check your coolant temperature sensor and conector for corrosion, if none you may tray replacing it, that may cure your problem, you did not specify any trouble codes, but make sure you change the sensor for the computer (two wires), not the gage (single wire) good luck
Jul 05, 2012 | 2000 Toyota Camry
We understand that your problem is: hi my toyota ae92 has a 2e engine. when the engine is cool the engine is shaking and the sound of engine is like a chopper. when the temp rise up till 1/4 the engine...
well this engines are notorius to rougth idle, but my sugestion is to inspect your coolant temp sensor, check for corrotion in conector if any clean or replace conector, your engine has two temp sensor one is a single wire for your temp gage and other believe green conector with two wires this is for your computer, if no rust or corrotion found replace the sensor.
good luck
Apr 04, 2011 | Toyota Corolla Cars & Trucks
1995 k1500 5.0 v8 manual trans setting a code 43
DTC 43 Knock Sensor (KS) Circuit probable cause is Signal to PCM has remained low for too long or the system has failed a functional check.
I wish you luck with that repair.
Jul 21, 2010 | 1995 Chevrolet K1500
No power, lots of smoke code p1247 neddle lift sensor
JUST A SUGGESTION 4 ELIMINATION ON THESE MODELS THE AIRFLOW METER CAN B APROBLEM A SIMPLE TEST WILL ELLIMINATE THIS DISCONNECT AIRFLOWSENSOR DRIVE UP ROAD IF CAR DRIVES BETTER THEN REPLACE AIRFLOW METER GOOD LUCK
Oct 09, 2009 | 1999 Volkswagen Jetta
No spark after cam sensor replaced - Frustrated!
hallo
check sensor: disconect conector. you have 3 wires. first(green) and last(black) are suppy should be around 5V. if not check wiring.
If ok: conect conector and access conector terminals (or wires) and conect LED test lamp between terminal 3 (black) and 2 (also black).briefly krank engine. Check that LED flashes.
hope it helps
Marko
Sep 10, 2009 | 2006 Fiat X1/9
I have a Rheem (Criterion) unit and i'am having promblems with the main burner staying on. When i turn the unit on everything operates like it should up to the main burner staying on.Once the main flame...
Run a wire from the sensor down to the control board conector. Bypass the sensor wire around the connector in the blower deck.
The connection can be wire nutted on the sensor lead with the wire (16 or 18 guage stranded wire works) routed through the blower deck to the other side of the plastic wire connector on the blower deck.
The Sensor operates at high voltage but very low current. The connector will sometimes fail due to humidity or wear.
I have seen this on the Rheem or Ruud furnaces.
Hope this helps.
Matt
Jan 07, 2009 | Heating & Cooling
2003 hyundai tiburon 4cyl wont start
I know there is no imoblizer on canadian modles not shure about american if there is that would be my first thing to look for
other then that you have changed alot of parts but have u checked any of the fuses or relays and dubble check that every thing is plugged in correctly if all that is good u have a wirring problem
Oct 19, 2008 | 2003 Hyundai Tiburon
Canon imageRUNNER 5570 Copier Logo
119 people viewed this question
old marine
old marine
