Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine making big noise during spinning
    Scholar:
  • 31 Answers
This can also be a shock issue. Generally when a bearing goes, you will also hear a "growling" noise when it goes into spin. If you are hearing the loud growling or grinding then definatly consider the bearings.
If not, take a look at the shocks. To test them, run your washer in spin with the front kick panel off (two screws hold it on into the front). If you can see your tub "bottoming out" on the shocks then you have your answer.
The shocks are easy enough to replace. Depending on which way the pins were put in you may need to remove the rear panel.
There are 2 white pins that hold the shock in place (one on the tub and one in the bottom of the cabinet).
There is a locking tab on each of the pins. The easiest way to get the pin out is to use a deep 1/2 socket. Place this on the tappered side of the pin. Go around to the other side and use a pair of vise grips (locking adjustable pliers) and pull the pin out. Do this on the top and bottom.
When replacing the pins it can sometimes be difficult to push them in. Use a long extension from a socket set and place it in the "rim" of the pin and use that as leverage to push in the plastic pin.
Posted on Oct 03, 2009
  • 379 Answers
Most likely this will be the drum bearings.
Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer.
Posted on Oct 02, 2009
dauphine
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
Its a bearing on its way out. the seal is also probably worn.
Posted on May 06, 2009
  • 2976 Answers
SOURCE: Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Posted on Aug 31, 2009
  • 38 Answers
SOURCE: Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Posted on Sep 27, 2009
  • 1891 Answers
SOURCE: washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Posted on Dec 14, 2009
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Final spins make big noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Aug 31, 2009 | Frigidaire FWT449
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
323 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
