Question about Kitchen Ranges
Rayburn reliability Ihave a raybun 480K which keeps on warping the heat plate/baffel between the burner and the oven.
  • 149 Answers
YOU WILL FIND THAT YOU HAVE A CRACK IN THE OVEN. THIS LETS IN MORE AIR THEN THE BURNER NEEDS SO MAKING THE BURN VERY HOT. YOU NEED TO FIX THE CRACK.THE BURNER NEEDS TO RETURN A READING OF 11-11.5 CO2 AJUST AIR TO MAKE IT THAT THE LOOK AT O2 IF IT IS HIGHER THAN 6.5ITS CRACKED IF ITS A MARK1 OR MARK 2 YOU WILL NEED TO CALL ME AS RAYBURN NO LONGER MAKE THAT PART AND I DO IF ITS AN MX OR MXE THE PART CAN BE GOT. info@topoftherangeltd.co.uk
Posted on Mar 19, 2010
Rayburn 480k heating control lockouts why? not always able to reset and no obvious reason help
Failed switches or plugs. Need to look at plugs or switches /relays. Check voltage and amperage.
Oct 16, 2016 | Cars & Trucks
Zanussi oven keeps cutting out
The reason for my free advice is GOD is good!
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
May 07, 2014 | Zanussi ZBF360X Electric Single Oven
Double oven keeps clicking on and off
Feb 23, 2014 | Whirlpool Ovens
Where do i put heat proof rope in my rayburn royal should it be around fire door, oven
no it should go under the hotplate to keep the gasses in the flueway and not in your room. you will need to stick one side down onto the top with heat proof glue.the hot plate then sits on top
Feb 26, 2010 | Kitchen Ranges
Smoke leakage from door and flue cowel needs rebuild/replacementin rayburn royal multifuel range
you need to take off the door and bend the hinge pins with a stronge bit of pipe so the door seals. heat has made it warp and do you mean soot box on the rayburn top? if so i have a new one i can send
Jan 07, 2010 | Kitchen Ranges
Rayburn 480 ag, pilot goes out
rayburn nouvelle thermocouple keeps burning out any suggestions
Dec 25, 2009 | Kitchen Ranges
Could you tell me if an oil fired rayburn will run ok on red diesel, I live in spain and kerosene is not available. thanks peter williams
if it is wick burner it will not work. if it is a single pj a gas oil burner can be fitted that will work. if a twin pj then it will work if you turn up the fuel pressure to 12 bar
Nov 29, 2009 | Kitchen Ranges
Kitchen Ranges Logo
306 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
