Question about FrancisFrancis! X3 Espresso Machine
FF X3 vs. FF X3 Trio - We are not POD people!!!
PODS just don't cut it. My husband loves his burr grinder and I love the footprint of the X3 which is getting old. Why is the X3 Trio limited to only using PODS? The X5 just doesn't have as good reviews!!!
    Problem Solver:
  • 5 Answers
The X5 has the same internals as the X3, so it really is a matter as to if you like the styling. The results from the X5 and X3 should be the same. Sadly you can't convert a Trio to ground coffee.
There is nothing about the X3 that should wear out in such a short time, so unless you have let the case get damaged - there is no reason it can't be brought back to as new condition. All internal parts can more or less be found though alternative suppliers, Lelit and Ascaso models share many components.
Posted on Nov 06, 2009
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
We have a new Classic. At first it was working quite well. We were in love. Then it started spitting at us in disconcerting fashion. We've played with the grind (burr grinder on fine, then finer, then...
you may have 2 problems that can cause this:
1 simply the filter in filter-holder is broken and it goes through without control(in this case we have girnded coffee too in cup)
2 lower burr plate in grinder is not leveled perfectly and you cant set to fine grinding even you hear metal to metal sound of burrs.
Feb 11, 2011 | Gaggia Coffee Makers & Espresso Machines
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
The plastic doser broke where can i get one?
Call these people.
They will email you easy instructions on how to fix the grinder, will sell you the part for cheap. I had the same problem, once you get the instructions it is very easy to fix.
Whole Latte Love
Customer Service
Phone: (888) 411-5282
Fax: (585) 924-7362
customerservice@wholelattelove.com
Feb 10, 2009 | Gaggia MDF Electric Burr Grinder
Grind
Love your 'handle'!
I'm thinking that there is something in the burr in the unit. Empty the unit and remove the burr. Usually, this is done with a counterclockwise turn. Note how hard it may be to turn...you'll have to reverse this when you put it together. Now, clean out any coffee debris you find. Then, turn the unit over and tap it on a firm surface covered with newspaper. Reassemble and return to service.
Nov 03, 2007 | Grindmaster 810 Electric Burr Grinder
FrancisFrancis! X3 Espresso Machine Logo
195 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
