Question about Siemens Washing Machines
The wash cycle starts and gets to 'wash' and never progresses. Stays on 'wash' for ever unless intervention occurs.
    Genius:
  • Siemens Master
  • 1,474 Answers
Sounds like timer prog ..Faulty ..not advancing
Posted on Oct 02, 2009
I have AEG Lavamat 60210 Front Load Washer machine. The machine stops after some cycles and time on the screen return to start. The Problem I get is E52.
Intervention of motor overheating safety cut-out.
Possible fault Motor faulty; Intervention of motor overheating cutout; Wiring faulty; Electronic board faulty.
Machine Status/Action Power to the heater unit and reversal of the direction of rotation are interrupted. If the problem does not re-occur, the alarm is memorized and the cycle continues. If the fault persists after several attempts to supply power (about 35 min.), alarm E51 is generated.
Oct 23, 2016 | AEG Washing Machines
Frigdaire top loading washer # FFTW1001PW gets stuck in wash cycle. It agitates and drains but stays in wash mode. Is there a way to fix this?
possible problem program board not progressing
call in a technician for a proper diagnosis and quote
Sep 03, 2016 | Washing Machines
Error code e63
E63
Intervention of auto-reset thermostat on the heater unit.
Possible fault Thermostat faulty (replace heater unit); Heater unit faulty; Wiring faulty; Electronic board faulty.
Machine Status/Action Disconnects the power supply to the heater unit. If the problem does not re-occur, the alarm is memorized and the cycle continues. If, after several attempts to restore power, the fault persists, alarm E62 is generated.
stolen right from google results
Jul 29, 2016 | Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Jul 19, 2009 | Dishwashers
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Washing Machines Logo
224 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
