Question about Harman Multimedia Harman Kardon GPS810 Portable Navigation Car GPS Receiver
It wont turn on.
Sometimes it wont turn on, or I will use it, then I will put it on standby and then try to resume the nav, and it it will not turn on. Even plugged in. As if the battery is completely dead, but I have not even had it a year.
I just reset it. Hopefully this works.
Posted on Oct 02, 2009
Psp green light wont go off
Sounds like you have it in standby mode. PSP turns off with the switch going the same direction as you turned it on. Back to the top, slide the switch all the way DOWN and it is in standby mode ready to resume your game just where you left off. Unless of course the battery dies on in which case you get to do it all over again because it never saved anything.
Nov 29, 2011 | Sony PlayStation Portable (PSP) Slim...
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
How do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Oct 25, 2009 | Samsung LN46B530 LCD TV
Computer won't resume after standby (os: vista)
Make sure all Vista updates have been installed, and check the ASUS website for any bios updates. I believe that motherboard had a known issue with stand bye.
Oct 18, 2009 | ASUS P5B Deluxe Motherboard
When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Wont come out of sleep mode
hi ck leapfrog,
thry this method done through about.com
right click on desktop > properties > screen saver > click on power > set the time u want your monitor to turn off ( but with the pc on ) and the hard disk also, but i would suggest give it more time with the hard disk.
and standby mode, i think it's what you want, it turns off the whole computer but if you touched anything, it will turn back on.
hibernate closes the computer completely but it's same like standby, coz the application will still be running and all.
about the welcome/login screen, click on advanced tab > under options, uncheck prompt for passport when computer resumes.
hope this helps.
regards,
voodoo
Apr 12, 2009 | Computers & Internet
Asus k8v-vm wont resume from standby.
get into the bios and change the setting to start from any key save yes and ok -esc
Jul 04, 2017 | ASUS K8V-VM Motherboard
Acer 5110 won't standby properly
Check the power-save settings / properties. You may have to hit a specific key to "wake" it up. To make things worse, sometimes you have to hit yet ANOTHER key to wake it from hibernate.
Jan 11, 2008 | Acer Aspire Notebook PC
Unusable camera
all you have to do is take the batteries out for a moment, and then put them back+ turn the camera on and off. This clears the glitch and normal operation will resume. . .
Nov 10, 2007 | Concord Camera Eye-Q 3341z Digital Camera
Harman Multimedia Harman Kardon GPS810 Portable Navigation Car GPS Receiver Logo
65 people viewed this question
Top Harman Multimedia GPS Experts
Are you a Harman Multimedia GPS Expert? Answer questions, earn points and help others
