My boot screen shows secondary slave hard disk error press F1 to resume. if i press f1 it enters into bios setup and the i press esc discard changes logging into windows but secondary disk is not detected. Give Me asolution ! please help me!!
  • 1 more comment
  • arunefx Oct 02, 2009
    Mine is SATA hard disk even i had tried with removing the jumper also the same problem exists
    I had replaced an another hard disk with the same cable and same port that works fine...
    But i want to mwke work my hard disk all my data in it
  • 4,281 Answers
Check on harddrive you find jumper on it.
Then read on harddisk you can find there is specifiaction for master, slave and cable select jumper settings.
Put jumper as cable select then check.
Also reconnect sata or ide and power cable to harddisk.
Then check .
Let me know if you need more assistance.
Thanks.
Posted on Oct 02, 2009
  • Change SATA cable.Then check Also change sata port on motherbord.
    Thanks.
I have a Western Digital WD1600AAJS drive. It was on a PC, got hit hard by malware. Need to copy off some critical directories from it. Plugged into another machine. Other machine will not fully boot with...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Jumpers for a PC hard drive are next to the power connector. Mostly in between the power connector and the data cable connector. These are used for setting up Master/Slave settings and also to limit capacity of the HDD seen by PC BIOS on some older hard disks. Usually settings which are selected by jumper setting to various locations are printed on the hard disk information sticker.
hope this helps
Apr 19, 2011 | Western Digital Caviar SE WD1600AAJS 160...
Hello sir, I have a problem with my Toshiba Dynabook 2140. I have changed its hard disk and I can't go to the bios setup menu how can I go to it. I have tried many times on hitting Del, F10, F12,...
Hussain - Greetings!
Do the following:
1. Turn on computer by holding down power button while pressing the ESC key.
The machine will beep, then display: Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
You should now have the BIOS screen
Regards, Mikeywaf
Mar 05, 2011 | Toshiba Satellite 2140CDS Notebook
My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
rescue disk will not boot your PC
to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
this should give you the solution
Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
Booting problem with my hp pavillion dv6000
it seems there is a problem with detection of hard disk drive.
as soon as you turn on the laptop press F1 key to enter the BIOS and check there to see if the hard drive is detected or not. If F1 doesnt take you into BIOS try F2.
Feb 04, 2010 | Toshiba Satellite A55-S1063 Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Apr 10, 2008 | Toshiba Satellite 5005-S504 Notebook
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
753 people viewed this question
David Payne
David Payne
