Question about UTStarcom Cell Phones
I downloaded my music files to the micro sd and went into my music and it had no content exists. music is on the micro sd though can you help me step by step
  • 416 Answers
Access your card from your computer and take note of the files.......your cell phone creates different folders for different menu options.
The folder should be music, but depending on your carrier could be labeled as sounds.....all files should be moved to this specific folder....so 1: access the media card 2: mover the media contents to the appropriate folder 3: your ready to go :)
another option is the copy the entire contents of the card to a folder on your desktop and format the card from the settings menu in your phone..............now you can look through the folders that the device creates to determine the one used for music......
geeeze.....hope i didnt lose you there
GOOD LUCK!!!! & Please Rate This Post!!!!!!!!!
Posted on Oct 02, 2009
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
Well i put music on my micro sd and when i went to my music player it said that it cant initialize the music db
Did you copy it from the micro-sd card to your computer then try to play the music? The micro-sd card does not have neccessary req's for temporary storage for active files. Try that
Mar 13, 2011 | Computers & Internet
How can you import pictures in inbox on cell phone to the microchip SD 2gb inserted in phone?
Micro SD cards for cell phones are now costing less and are holding more memory. 4GB SD cards can hold an estimated 1000 songs, over 13,000 images, or 22 hours of video individually. 2GB memory cards hold roughly half those estimates and 8GB SD cards would hold double. So if your cell phonemag-glass_10x10.gif has a SD card slot learn how to utilize this expandable memory option on your device. Follow these steps and you will soon be enjoying your music, pictures, and video on your phone!
  1. Insert your SD memory card adaptor (with micro SD card inserted) into your SD Card drive on your computer. This should open a "Secure Digital Storage Device" or similar window. If not, go to "My Computer" to locate your SD card and open it.
  2. Step 2 To transfer picture files to your SD memory card, open the folder or file that your pictures are stored on. Simply click and drag a file or multiple files and drop them into your SD Card window or folder. You can also copy a picture and then paste it to the SD Card.
  3. Step 3 To transfer music files to your SD memory card, open your "My Music" folder. Select the folder where you are going to get the music from (Itunes, Yahoo Music...). Click, drag, and drop the files into the SD Card window or copy and paste them in.
  4. Step 4 To transfer video files to your SD memory card, open your "My Videos" folder. Select the folder where you are going to get the video from. Click, drag, and drop the files into the SD Card window or copy and paste them in.
  5. Step 5 Take out the SD memory card adaptor from its drive. Remove the Micro SD card (small chip for your phone) and insert it into the SD Card drive on your Blackberry, IPhone, or other compatible cell phone.
  6. Step 6 Go to your media, picture, or music folder in your cell phonesmag-glass_10x10.gif menu. Select which item you are looking for and your files will appear!
Nov 14, 2009 | Cell Phones
Files downloaded to micro sd phone (motarolave240)says micro sd does not contain supported music files
See what format of music you have put in,see whether the format is compatible with the phone.Also make sure you have a software on your phone which can play the music files.Hope that clear your mind,and help you
Sep 06, 2009 | Cell Phones
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed...
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Dec 23, 2008 | PNY 2GB microSD Memory Card
PNY MICRO SD 2GB
Files must have the correct extension. i.e. .wav or .mp3 or whatever the music player requires. You may need to convert the sound file to a different type for the device to see it. It may show in one device and not another for this reason
Apr 09, 2017 | PNY 2GB microSD Memory Card
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Cell Phones Logo
63 people viewed this question
Top UTStarcom Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
