Question about Canon PIXMA MP600 all-In-One InkJet Printer
I have problem with my mp600, in the lcd displayed error code u52. how to fix it?
    President:
  • 1,653 Answers
This means The type of print head is incorrect. Install the correct print head." U052
The solution is follow the directions given in the Easy Setup Instructions to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it.
If the error is not resolved, the Print Head may be damaged and may need replacing.
Posted on Oct 02, 2009
  • Hammerman123 Nov 17, 2010
    How do you even know which print head it is? There are 5 cartridges and none say u052
  • 41 Answers
SOURCE: my canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
Webcauldron
SOURCE: error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Posted on Mar 02, 2009
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
pineworks
  • 4041 Answers
SOURCE: Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Posted on Jan 27, 2010
pineworks
  • 4041 Answers
SOURCE: Canon mp 600, errorcode 5c00
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
  7. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Panasonic error codes fp2 u52
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Apr 25, 2013 | Panasonic ET LAD10000F Projector lamp...
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010 on cANON MP600 ALL IN ON PRINTER
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
3. Wait until the device has completed its cycling process before submitting another job request."
Jun 16, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Oct 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP600 PRINTER
To do a stop/reset:
Good Luck!
Maggie B
Feb 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error code
Click the link for Cannon:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13800#SupportDetailAct
Under Please enter your question:
Type in error code 6502 Click Search
Click number 1
ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Feb 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
2,411 people viewed this question
old marine
old marine
