Question about LG KC910 Renoir Cell Phone
LG Renoir Battery issues
Phone dies after a very short time while on a phonecall even after I fully charge the battery overnight. I used to be able to use the gps for a full 10 hour drive form Sydney to Melbourne and still have battery left. Now even after charging the battery completely, I can't even have a 2 minute phonecall or go online before the phone just turns itself off. If I leave the phone for a few minutes and turn it back on the battery bar still shows as full.
My renoir has just developed this issue.
I have tried 2 batteries, tried re-flashing the firmware (even tried a custom firmware) and nothing.
I am buying another battery to see if i were unlucky with the battery I bought.
This does not appear to be an uncommon issue as I have found several threads online regarding this. No definitive answer as yet.
Posted on Apr 05, 2010
  • geoyouknow Apr 05, 2010
    bought.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
It can be the problem of battery itself or of the operating system. try changing the battery, operating system. thats the only things that u can do
Posted on Oct 02, 2009
Samsung galaxys 2 drain battery fast
The power cell should only get warm if you have it powered on all of the time. That is natural. 6 hours is short, and that may be one of two problems, the time of charge is too short, or the battery is dying. HINT! If you replace with a NEW battery; you must set the battery memory for the start. That means, when you first charge it, make certain it gets a long 24 hour charge to full. Use the phone until the device shuts down because the battery was exhausted. Now Do a full long term Charge. That process will set a Memory for the Power Cell and allow you to fully charge and discharge the battery from there on. One more thing...if you use a Charger Device, make certain it is working OK or else the Battery will not charge well.
Dec 12, 2013 | Samsung Galaxy Tab 2 7.0
Very short battery life
Often this is the result of keeping the device plugged into a power source all (or most) of the time, even when it is not in use. The battery literally looses it capability to hold a good (long) charge.
So, you'll need to keep the device plugged in (to a power source) every time you need to use it ... to continue using it. Or, you may wish to replace the battery. And if / when you do, just remember to charge it fully, then unplug it and use the device (to run only on the battery) until the battery is depleted before plugging it in to charge it (to full) again. This way, the battery will last longer.
Aug 08, 2013 | Tomtom GO 920 GPS Receiver
Battery did fully
I don't know what you mean by that, but i am guessing you meant that your battery didn't fully charge? I have an answer if that is the case.
i can assume your device uses a Lithium-ion battery. When dealing with these batteries it is best to charge them often. If you charge the GPS to full then let the batteries go all the way down before recharging you are hurting the life of your batteries as well as the amount of time you can get at a full charge. 80% depth-of-discharge is recommended. Also the batteries age even when not in use, so if it is old get a new one.
if this is not your problem at all then im sorry you will need to clarify your post.
Jul 28, 2009 | Dual Electronics XNAV3550 Car GPS Receiver
LG viewty ku990 - no battery life and phone gets really hot
So many issues here so lets take one by one.
Phone not charging or goes off before the recommended time means your battery is bad and needs a replacement. Batteries are not serviceable and hence cannot be repaired or fixed. You just have to change it.
PC not recognising USB port is due to an issue with the driver the PC needs to communicate with your phone.
Get the right driver and PC Suite to enable your PC recognize your Phone through the USB
May 27, 2009 | LG KU990 Viewty
Wont turn on
batteries have a specific amount of electrons it can hold, but when a battery is finishing the working time reduceses, if you can access a avo meter you can check some current, using amps range on the meter before buying another one. thanks
Mar 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Battery died and or charging system failure
I think its probably your only choice, NIMH batteries are known to have a very short shelf life if not regular charged / discharged you can get GE cordless batteries here - GE Cordless battery
Jan 10, 2009 | Uniden Cordless Phone
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Nov 15, 2008 | Garmin StreetPilot c550 GPS Receiver
I charge my LG KU990 full over night within 12 hours the battery
You just have to charge it fully but not for long as soon as it turns full battery then swithch ur phone off then take the battery out for a sec then put it back on then turn ur phone on then it will work for a longg timeee kk..
Nov 13, 2008 | LG KU990 Viewty
After fully charging my Motorola H700 all night, it loses its charge after an hour or two. When I plug it back in, the green light comes on in seconds. What's up with that?
seems some components inside your phone has shorted out. overnight charging is not recommended for it could cause overheating of the components of your phone which in time develops shorts.shorts , of course consumes rapidly the charge of the battery and it damages the battery also. have your phone diagnosed and fixed. next time if possible, remove the phone from the charger when it fully charged.
Nov 01, 2008 | Motorola Cell Phones
LG KC910 Renoir Cell Phone Logo
961 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
