Question about Linksys Wireless-G WRT54G Router
I have a Linksys wrt546 router. How do I enter the routers IP address.
  • 4,281 Answers
First connect your router to computer with ethernet cable then you can access it with defaults link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router.
If are not able to access it then go to start menu then type in run "cmd" then you see command propmt
Type in prompt "ipconfig /all"
then gateway ip is your router ip so you can access router with that gateway ip.
Still not able to access then reset router .
Press RESET button for 10 seconds it is in back panel of router.Then you can access it with above link.
Let me know if you need more assistance.
Thanks.
Posted on Oct 02, 2009
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Step 2:
NOTE
Step 3:
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Cant access my router ip number
go to start then click run adn type cmd then press enter, on the command prompt type ipconfig/all then press enter then look for gateway IP address, that will be your router's address unless you have a static IP set up on your machine.
Sep 14, 2009 | Linksys Wireless-G WRT54G Router
Unable to Connect to Internet
Make sure that the cable/dsl modem is connected to the blue port on the Linksys router that say's internet and your computer to any of the yellow ethernet ports. Check what is the IP address of your computer by typing ipconfig on the command prompt(assuming your using Windows, to open command prompt click start and go to Run and type cmd, a black windows will open normally it will say C:\Document\Settings\Owner>. Your computer should obtain an IP address of 192.168.1.x, open Internet Explorer and type this address on the address bar http://192.168.1.1 when you get a prompt for a username and a password, leave the username blank and type "admin" for a password from there you can now check the entire settings of your linksys router, check the Status and make sure your router is getting a valid Internet IP address if not you may require manually setting up the configuration of your ISP on the router.
Aug 29, 2008 | Linksys RangePlus WRT100 Wireless Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
