This is jeff I just received an answer to my problem with my Toshiba 57H82 57 in. Rear Projection HDTV. The answer was " Try Wathing the Picture in Picture " But I don't know what Wathing Means
srry . watch the picture in picture . the sub video path takes a different route through video processing and may look ok. the pip control button should be at the bottom of the toshiba remote.
Comments:
Oct 02, 2009
- if you get the picture in picture to work and one is a lot better than the other then it rules out many parts of the tv like deflection and convergence as suspects
I have 2 vertical lines on my 57" Toshiba rear projection. One (left one) is red and the other...
(More)
I have 2 vertical lines on my 57" Toshiba rear projection. One (left one) is red and the other (right one) is green. I don't think this issue is there when using PIP, but I'd have to check again when I get home
We have a Toshiba and the on button just flashing and we can't get any picture to come on - any...
(More)
We have a Toshiba and the on button just flashing and we can't get any picture to come on - any suggestions?
My Toshiba Cinema Series tv went out today. After the unit was on for 10 minutes, it went partially...
(More)
My Toshiba Cinema Series tv went out today. After the unit was on for 10 minutes, it went partially black screen with horizontal lines on the top and bottom. I turned it off, back on with only the power button on. Turned off and back on, picture came in fine, then went back to blank screen. The red light next to the power button is on when I turn on the tv but now no picture or sound. Can anyone help me resolve this problem? Is there a way I can repair myself?
I have a 57HX93 rear projection big screen that won't power on. Power strip and wall outlet are...
(More)
I have a 57HX93 rear projection big screen that won't power on. Power strip and wall outlet are working. Can I fix this or do I need a repairman? Or is the TV done.....
