Question about Acer AC713 17" CRT Monitor
It says re-install the copy of
It says re-install the copy of /system 32/hal.dall
    Guru:
  • 355 Answers
Hi im having problems with my operating system windows xp is there a free xp download all i get is <windows root>\system32\hal.dll re install a copy of this file
It seem a vital part of window was moved or deleted. Please check/follow below tips :
1. If you have CD installation you choose repair to fix this. If not,..
2. 'Find' the 'stolen system 32' anywhere on your HDD. It may still in recycle bin, if no luck..
3. You can use 'System Restore' to the date which is your computer working fine ( note some data will lose, except you back the data before proceeding this step).
Good luck.
Sep 21, 2011 | ASUS Computers & Internet
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
My gateway lt 20 goes to a missing mess.about <windows root>\system32/hal.dll. immeditly on startup
If it cannot access any of the Advanced Boot Options, you may need to reinstall a fresh copy of the Operating System. However, try to run a hard drive diagnostic software to check if your hard drive has bad sectors.
For advanced troubleshooting on how to reinstall the file (system32/hal.dll) without doing a clean install, check the link below.
http://support.microsoft.com/kb/945380
Hope this helps.
Jun 09, 2011 | Computers & Internet
Sometime after installing some cd which came with a childrens interactive book, I received a message saying Windows could not start because the following file is missing or corrupt: &lt;Windows...
There are about three things that might have happened. They're all mentioned at the following link:
https://neosmart.net/wiki/hal-dll-missing-corrupt/
Any Windows CD of the exact same Windows version can be used if you decide to try that route. You're really just looking to repair Boot.ini or hal.dll
Oct 02, 2017 | ZT Group Cisnet PC Desktop
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Error message when starting up: <Windowsroot>\system 32\hal.dll. Please reinstall a copy of the above file.
This issue happens if boot files are corrupted .. you need to have the Operating System Cd to resolve this problem . Considering you have windows xp you need to have the installation cd for windows xp .
you need to use bootcfg command to resolve the issue.
Go to bios and change the boot sequence to boot from the cd, if you are not able to boot from the cd. and then boot using windows xp cd .
Then push R to go to recovery console and use the below command
Boot to Recovery Console and rebuild the BOOT.INI file with the BOOTCFG /REBUILD
command.
May 09, 2009 | Microsoft Windows XP Media Center Edition...
Acer AC713 17" CRT Monitor Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
