Question about Kicker KX400.1 Car Audio Amplifier
Protection light comes on. what is it and how do i fix it
  • 21 Answers
Wire connection is not right or the power source is not enough. Make sure the radio wires connected to the car are correct and that the usually blue and white REM wire from the radio is connected to the REM position in amp. Power source must be straight from battery not from anywhere else. Ground wire should be connected any metal bolt in trunk or to a new hole drilled into frame. Also make sure that the wires for speakers are running on 1 side of the car and the power is on the other side, never together on same side of car. Hope this helps.
Posted on Oct 02, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Almani protection light coming on
fix your ground make sure its thick as the power and its touching bare metal
Mar 13, 2013 | Almani Car Audio & Video
My amp has a protection light on need to know how to fix. When I pull the fuses out the power comes in but when I put the fuse back in the protection light comes back on
From the description your audio output transistors or ic's have a short causing a load problem activating the protection circuit. Turn volume right down, power off, remove speaker wires from the back, power on! if protection kicks on it is the audio outputs in the receiver, if not! check speaker wires for shorts, hook back one at a time until defective wire or speaker is located. The audio outputs will need to be addressed by a technician since there is complexity involved.
Mar 03, 2012 | Legacy Car Audio & Video
The protection light is lit as stays lit and i have no sound coming out
if the protection light is on its an hardware failure
the protection unit will not let you power on the Amp
need to take to service
if you want to fix the amp let me know
ecrdn@yahoo.com
Jack
Oct 18, 2010 | TOA Electronics P-924MK2 Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
Protection Light
when the protection light comes on means either you have something like you power and bround backwords,or you have speaker wires touching somewhere..
Dec 04, 2008 | Alphasonik PMA1200D Car Audio Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
PROTECTION LIGHT
Disconnect the speaker wires and the RCA cables from the amp. If the protection light still comes on, the output transistors have likely failed.
Nov 02, 2007 | Lanzar VIBE531 Car Audio Amplifier
Problems
chenge and replace the safe of the amp
May 22, 2007 | Kole audio Q2-1920 Car Audio Amplifier
Kicker KX400.1 Car Audio Amplifier Logo
230 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
