Puts small holes in washing
When used makes little tears in clothes usually new ones
  • 101 Answers
Check to see if agitator isn't loose letting clothes go under the agitator.
Posted on Oct 02, 2009
Why is my whirlpool deut washer tearing clothes
Check the little holes around the drum, I have seen pins and needles get stuck in these and cause lots of damage. I would replace the seal.
Apr 10, 2013 | Washing Machines
Washer ripping clothes
Check the drum baffles (the paddles inside the tub) to see if one is loose and also check the front tub seal for any tears.
Nov 05, 2012 | Washing Machines
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
Some of my clothing is getting small holes appear ie t shirts and some times jeans i don't over load today it has ripped a towel
There could be several reasons:-
Incorrect use of chlorine bleach
Unfastened zips, buckles hooks or fasteners
Ribs, tears and broken threads
Degradation of material
Hard objects left in pockets
Some sharp foreign object caught in holes in the drum and ripping clothing - feel all around the inside of the drum for sharp objects.
Apr 11, 2011 | Bosch Washing Machines
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
We are getting small holes in our clothes? Is
check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
Aug 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
I have w460 & i keep getting small holes in tee shirt type materials help!
most likley you have a rough surface in the drum, you may have had a underwire from a bra poking through one of the holes in the drum which has now distorted the hole allowing a sharp edge to protrude inward and damage the clothes. empty the machine use a torch if needed and rotare the drum looking at the surface for inperfections (dipmles in the reflection of the surface) once found use something wood or plastic to push the burr outward) away from the clothes I used to use a soft screw driver handle to move the burr away. if its not this then check the door gasket these can wear away and start to tear clothes but this usually looks more like a burn than a small hole.
Jul 20, 2009 | Miele Novotronic Premier 500 Front Load...
LG Washer leak, small tear in door seal
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Jul 04, 2009 | LG WD-1080FD Front Load Washer
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
