Question about Whirlpool Washing Machines
Washer stops at rinse
Washer stops at rins, what could be wrong?
  • 905 Answers
Most washers will rinse in cold water only, some have a choice. If your washer rinses in cold only, then the valve for cold water is turned off, or the solenoid that allows cold water to flow in is not opening like it should.
Posted on Oct 02, 2009
What makes Washer not rin?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you may have selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
Jan 09, 2017 | Washing Machines
Washer stopped in rinse cycle.
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops with an F-21 notice. Somehing wrong
drainage pump inside washer is broken. Most likely some debris buildup around pump. Mine just did the same thing a couple of days ago. new pump cost about $126.00
Aug 10, 2009 | Washing Machines
Washer won't rinse or spin
Sounds like either the timer drive motot is crook (if it,s not clicking on ) & if it is & stopping at rinse Check your button trap on pump for obstruction & or burn,t out pump.Hope this helps Cheers.
Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Aug 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Aug 31, 2006 | Beko 24 in. D3731F Free-standing...
Washing Machines Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
