Question about Syntax 427V 27 in. LCD Television
Olevia ACL TVHD, model# 427V. LCD, 27" flat panel. The screen has many many vertical lines of all different colors. No type of picture, althought I can not verify which input it is getting it's signal from. Nothing comes up when I attempt to push the menu button. I searched similar problems, and am suspect of the digital tuner. Does this sound right? Plus, I have an old analog TV connected to a digital converter in the same room, a few feet away from the Olevia flat panel now. When I turn on the Olivia the other TV's digital signal gets completely scrambled and fails to receive a signal.
  • Dain Epperson
    Dain Epperson Oct 02, 2009
    No remote came with the TV. I am working purely from the TV itself. I am un able to change any settings because I get no responce from anything, except for the power button. Most of the screen is blue, except for the multiple multi-colored vertical lines running through it. When i push the "menu" and "channel" and "volume" buttons on the back I get absolutely no responce.
  • 3,741 Answers
That's the TCON board (timing control) causing that...if it's not integrated into the LCD panel it only cost's about $150.00 for it.you will have to replace the TCON board.many users are facing this same problem as yours of vertical multicoloured lines on the screen.this causes due to faulty tcon board. -------------- you can get the required board from www.shopjimmy.com or from ------ www.radioshack.com ------------- this will help.thanks.please do rate the solution.thank you for using fixya.keep updated,.
Posted on Oct 02, 2009
    President:
  • 1,462 Answers
I consider this a work around more than a solution.
While studying the problem, I think there must be speaker hum, non responsive remotes, and various other problems that all seemed to be tied to the back-light intensity. For whatever reason, the system voltage on the tv seems to be affected by how bright the bulbs burn. More power to the bulbs means more power everywhere.
Following that train of thought, Use the Lighting button on the remote and changed to "Bright Room", then tune the tv off/on. an check whether it works fine
The problem is almost certainly affect some component(s) on the main board.
I read same issue once. Power on, no digital channels, and auto search does nothing. I've read somewhere that the remote had issues and can send wrong signals. Took the batteries out from the remote, switch the TV on from the TV unit, and it works. Try it couple of times and check whether the things are OK. Put the batteries back see whether it works.Please try it and let us know so we know if the remote is the source of the issue.
If it still doesnt work, try changing the main board and it should solve your issue..Try finding a retailer and ask for stan by main board till your main board get serviced..
please leave me comment, if you need further assistance
RNJ VINODKUMAR
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
I have a Olevia LCD HD TV that has no sound no picture n vertical colored lines??? Any answers or suggestions or is this tv DONE??!!
we unless you spend money on it to repair it is done for sure .what do you have as an input , antenna or cable or satellite service
Jan 22, 2015 | Olevia Televison & Video
Sanyo 18.5 HDTV LCD TVHD ACL DP19640. I have sound, no picture. I have checked everything else & is working properly.
If sound is there, surely the picture too. If there is no picture, its back-light inverter board need to be checked. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 02, 2014 | Televison & Video
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Dec 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Dec 01, 2009 | Samsung LNT4066F 40 in. LCD Television
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Nov 16, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Syntax 427V 27 in. LCD Television Logo
80 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
