Question about Amphion Mediaworks T-365 System
I'm trying to connect my playstation 3 to my amw t365 but am failing. I have the optical cable connected and the audio configuration changed on the ps3 system but still no sound comes out.
  • rbevansiii Oct 02, 2009
    do i connect the optical cable to the optical out port on the amw t365? do I select dolby digital 5.1 ch as supported format on my ps3 settings? can you walk me through how to change the necessary settings on the amw t365 itself?
    this did not work. The amw is dolby digital surround but i dont know how to change the input settings to optical (on the amw).
  • 3,267 Answers
These are the specs:
Features/Specifications:
  • AMW-T365 DVD Player 5.1 Home Theater System and Stereo Receiver
  • General Features:
  • Stylish silver design
  • Built-In Dolby Digital Decoder:
  • Dolby Digital output
  • Dolby down-mix dual channel
  • Dolby Digital decoding
  • Multi-Format Disk Support:
  • DVD, VCD, SVCD
  • CD, MP3, CD-R, CD-RW
  • Kodak Picture CD (JPEG)
  • Audio Advantage:
  • 48K/96K, 24bit
  • E.Q. Genie (7 modes to select)
  • Diversified Sound Effect
  • Video Advantage:
  • MPEG-2, MPEG-1
  • 10bit Video Decoding
  • PAL, NTSC playback
  • Screen aspect ratio selectable (4:3 and 16:9)
  • Smart Content editor
  • Multi-Angled View
  • Multi-language OSD (8bit On Screen Display)
  • Multilingual Dialog up to 8 tracks and 32 subtitles
  • Advanced Progressive Scan
  • Video Input/Output:
  • S-Video output
  • Composite Video input, output (AV)
  • Advanced Progressive Scan (Only for Component/Y-Pb-Pr)
  • Audio Input/Output:
  • Optical input (1)
  • Optical output (1)
  • AUX Stereo input/output (2)
  • Amp & Driver:
  • Subwoofer: 50W- 5.25" Woofer
  • Center: 15W- 3" Full range
  • Satellite: 15W- 3" Full range
  • Unit Dimensions:
  • DVD Receiver: 16.9 x 2.4 x 12.8-inches
  • Speakers:
  • Subwoofer: 8.7 x 14.4 x 11.2-inches
  • Center: 8.7 x 4.3 x 3.3-inches
  • Satellite: 3.8 x 6.7 x 3.3-inches
  • Others:
  • Digital AM/FM Stereo Tuner with 40 presets
  • Full Function Remote Control
  • Power Requirements:
  • 110V-/2A 47-63Hz
Package Includes:
  • One (1) AMW-T365 DVD Player 5.1 Home Theater System and Stereo Receiver
  • Five (5) 15W satellite speakers
  • One (1) 50W subwoofer
  • One (1) Composite video cable
  • Four (4) 10-foot speaker cables
  • Two (2) 25-foot speaker cables
  • One (1) remote control w/ battery
  • AM/FM wire antenna
  • Quick setup guide
  • User manual
Additional Information:
  • Product Requirements:
  • TV with the proper inputs
  • DVD movies
  • Power outlet
  • Notes:
  • Model: AMW-T365
  • UPC: 8 25939 00027 9
If you have noticed/observed that it cannot read *.wav format(sound) and generally PS's DVD/CD have the corresponding decoder, plus the signal has to be digital recording whereas most almost all PS's have analog output. Thus no sound.....................................sodeep
Posted on Oct 02, 2009
    President:
  • 1,462 Answers
Please follow the procedure to enable optical sound output from your PS3 to amwt365:
  1. Connected the optical cable to your ps3. If you see a red dot on the end of the cable, you can assume that thing are going good, if you dont see red dot, ifs problem with the optical cable.try with different cable
  2. Connect the other end to the AMW home theatre, and you should see the same reddot even there in your AMW
  3. Chang the sound settings on the ps3 to optical use optical
  4. Switched all sound settings & input devices to optical from your AMW system
Now it should work fine, still if it doesnt work, then
  • Try to check, whether have you selected the optical out in the sound settings menu of PS3 and selected compatible sound formats?
  • Did you set sound output to bitstream in BD/DVD settings menu on PS3?
Please leave me comment, fi you need furthur assistance
RNJ VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Oct 02, 2009
    You should connect it to optical IN of your AMW and the setting depends on your AMW specification..
    Try changing the formats one by one, till you get sound..
    If this soluton works, please change the rating for this solution to better one..
    RNJ VINODKUMAR
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
LET ME KNOW HOW TO CONNECT A MICROPHONE TO Dav dz260
unwrap the cables and match them to their colour on the back of the speakers, front side, back rear, front & woofer.
Plug in the connections to the back of the DVD player, again all coded.
Turn system on and it will guide you through the sound setup, what this does is tweak the speakers for balance and power, then place the sound check mic in the middle of the room, then its best to get close to the door and press ok to test system, then leave the room shut the door while the sound configures, it takes about 3 - 4 mins and high pitch noise shoots around the room. buy 3 Optical Cables for PS3/HDTV and a Splitter, all working perfect.
Put on your favourite film and sit back and watch,
Playing on PS3, you need to go into audio setup to change to optical audio, this then allows the system to go through the home cinema.
just switch on the TV setting on your home cinema (aka DVD player) and this triggers your sound for the PS3. If you are using this late like I am having a young family it is best to turn the night setting on (easy click on the remote) this reduces the woofer base allowing everyone to enjoy the eve/night;-)
I have been using it for a week now and am still amazed by the quality.
In a Nutshell - HDTV (with Optical Out), Playstation 3 (with Optical Out) and the Home Cinema (with Optical out), I advise buying 3 optical cables and a splitter, one from the home cinema to the splitter main input, then channel one from the splitter to Playstation 3 and channel two from the splitter to HDTV. Its best to note that the Optical Cables do take preference over HDMI Cable therefore no sound will work through your system, with PS3 you have to go into the Sound Settings and change from HDMI to Optical and select the 5.1 channel for total surround.
Nov 18, 2011 | Audio Players & Recorders
I have a panasonic viera Tc-L42D2 Tv and have a amwT342 5.1 home theater system and has it connected using the opitical cable which i was told by panasonic that the only audio connection is the opitical...
Very sorry to inform you that the digital optical socket at the back of your AMW T342 is not digital in but digital out. In other words you can connect the audio output of the AMW to another device like a AV Receiver or a Digital recorder etc and not vis versa. They have not provided a digital input and unfortunately your Panasonic TV only has an optical digital out for audio .
Mar 21, 2011 | Audio Players & Recorders
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
PS3 Digital Audio (optical) out no longer working
Check you audio settings are correct on the ps3 dashboard. Failing this try swapping the optical cable or connecting to another devise to see if it working.
Post more info if you need further help
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
Difficutly with connecting optical digital cables
Yes the digital audio cable should be inserted until there is a firm, clicking connection. It should only be able to fit in correctly with one orientation. It should be slightly difficult to remove when properly connected.
If your cable is slipping out, then I suggest you have a defective cable or (hopefully not) a damaged/defective optical connection port.
Apr 07, 2009 | Sony Playstation 3 (PS3) Console
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Amphion Mediaworks T-365 System Logo
106 people viewed this question
Top Amphion Mediaworks Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
