Question about ASUS A7V400-MX Motherboard
CANT CONNECT A 1TB SEAGATE 7200RPM HDD. oRIGINAL BIOS ON MOTHERBOARD
  • ASUS Master
  • 32,281 Answers
The BIOS may not be able to support a hard drive of such a large capacity. Check the motherboard manufacture's WEB site to see what size hard disk the BIOS can support. There maybe a BIOS upgrade that will allow the motherboard to support larger hard disk capacity.
Posted on Oct 02, 2009
Testimonial: "Am trying that . will check and revert"
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
How to connect a SATA2 HDD to a SATA1 motherboard?
It should work. If not, there are jumpers on some drives. Not a DIY task because it requires unusual skills. Does not always work in any case.
Jul 06, 2014 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hi , seagate 1tb Expansion portable drive S/H: 2GHY01LD error in page operation plz help
Go to Start, right-click on My Computer icon and select Manage
When you go to manage, select Disk Management.
Click on Disk Management and you will notice all the disks (HDDs and any removable devices on your right column.
Click on the Seagate 1tb HDD,
(1) Note the file system
(2) Note the Status of the drive
(3) Note Fault Tolerance
(4) Then Notice the HDD if it is Basic or Dynamic
If the HDD is Basic, right click on it and create a partition.
Then move some of the Data on to the new partition to free up the old partition. Restart the computer and abserve the results...
That usually happens when the Hard Disk driver is running out of space or you have less RAM..
Aug 23, 2011 | Seagate 1TB 7200RPM 64MB CACHE...
My hard drive is recognized in bios but windows will not format for windows 7 install
You have to have the current drivers loaded on the motherboard for the HDD to be able to load your operating system.
Jul 16, 2011 | Seagate Barracuda St31000524as 1 Tb...
SIR I AM PURSHES SAMSUNG 1TB INTERNAL HARD DISK MODEL NO: HD103UJ INSTALTED MY SYSTEM(intel945M/B)HDD DETECTING IN BIOS ONLY VOLUME 32MB HOW SOLVE THIS PROBLEM
Take out the hard drive.
At the back of the hard drive you will find a jumper. pull it out and change the location or put it at the end.
connect the hard drive and check.
Dec 02, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
How can you connect a seagate 250gb external hdd to a ps3 120gb
i have just bought a seagate external 1tb hdd to store more stuff on but it wont connect to my ps3 slim 120g what can i do
Nov 16, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Cant detect hard disk
hi all,i just had the same problem, heres how i fixed it.
in bios, check you settings
if using ide and sata, enable combo cable select
check motherboard compatability 1.5gps or 3.0 gbs
if 1.5 insert jumper on back of HDD
check now in BIOS to see if HDD seen.
now boot windows, open control panel, administrative tools, computer managemant, disc management and select drive, it may need to be formatted.
Dec 19, 2007 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
ASUS A7V400-MX Motherboard Logo
202 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
